I found solution for my problem. Need reboot windows with Kess connected. That solve my problem!
morgano (15th April, 2019)
https://mega.nz/#!Cp4RQCiA!YPj8GQC_X...h8GjWPL5EnOl2M
In this version, protocol 445 is functional
Unzip in 7-zip
Yes it's a china card. But I tried to use files from the 1.st post multiple times and the 445 protocol is: Protocol is not firmware compatible
Confirmed by kitnoos, who made my new card
Why do not you take your original files to create a new SD.
The SD cards files from the first post are not mine!
Protocol 445 uses the file FL0468.prt
I just compared the files:
FL0468.prt from the first post = 19720 bytes
FL0468.prt from the China SD = 19724 Bytes
I compared all the files:
The FL0468.prt, FL0497.prt, and FL0513.prt are not identical with China SD card
Thank you, but I can't do it on a new card from my origo card.
I managed to make a 2GB card using the 1st post, but it doesn't work there 445. When I use a larger card, I have an EEFace error.
Probably the bold question of how you managed to remove my FL0468.prt from my card ?
tkmmazda (27th April, 2019)
Who can share china 5.017 SD folders?
Jerak (9th May, 2019)
hello guys,
plz i need download link for " 20 BE 0B E0 07 CB 58 11 81 ED 01 59 6E 79 FB BF.zip "
because i can't download it from attachment in 1st post
regards
Dreambox Developer
--CLi Team--
--U.R Team--
