Kess 5.017 how to read SD card or create a new SD card - Page 18
Page 18 of 62 FirstFirst ... 8131415161718192021222328 ... LastLast
Results 256 to 270 of 929
  1. #256
    Jul 2019
    Hello
    I just would like to tell you that I managed to prepare a new sd card – Thanks Boxsport for all the help.
    To be honest it is not so hard, but you need all the right tools and go step by step, like it is written in the manual. All you need is:
    • Kess 5017 New SD Vers3.pdf
    • WinHex (registered version)
    • KeyFileGenerator.cmd
    • XorFiles.exe
    • archive folders from "Ksuite"
    and you can do it.
    I can't believe that seller did not help me and refuse to help me,... it was so easy – once you get all the tools and info.
    Thank you once again from all that help forums like this live…
    Regards.
    Rok
  2. The Following 7 Users Say Thank You to Bluebeast For This Useful Post:
    Carl (1st February, 2024), diagauto44 (16th January, 2023), dmerkovic (30th July, 2023), duronur2005 (6th August, 2023), jlfalagan (10th December, 2023), kev bmw (14th January, 2020), Leizerutz (18th July, 2023)
  3. #257
    Oct 2011
    Germany
    Quote Originally Posted by Bluebeast View Post
    ....Thank you once again from all that help forums like this live…
    and do not forget to press "Thanks" Button
  4. The Following 12 Users Say Thank You to bergbahn For This Useful Post:
    badici (25th December, 2019), Bluebeast (29th July, 2019), diagauto44 (16th January, 2023), duronur2005 (6th August, 2023), hamdaniptt (16th January, 2020), jlfalagan (10th December, 2023), JuhnuAW (28th April, 2022), laki23 (15th August, 2022), Leizerutz (18th July, 2023), paolo poppi (8th January, 2020), zas010970 (23rd September, 2022)
  5. #258
    Feb 2019
    How can I have acess to all the files needed? Thanks
  6. #259
    Jan 2019
    I've tried to make new SD card. Everything had been done by instruction of creating new card (all steps one by one). Still have "protocol not found" error. Can anybode help me to reanimate Kess 5.017?
    Thank you!
  7. #260
    Aug 2019
    Good day,
    Where can I download the keygenerator.cmd file from?
  8. #261
    Jan 2019
    Somewhere between Continents
    Quote Originally Posted by Cerera View Post
    Thank you!
    hello there...
    were you able to sort this out?
    Cheers
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  9. #262
    Jan 2019
    Quote Originally Posted by bloubul7 View Post
    Good day,
    send you PM.
    Cheers
  10. The Following User Says Thank You to boxsport For This Useful Post:
    badici (8th February, 2020)
  11. #263
    Feb 2017
    Netherlands
    I'm looking for the "keygenerator.cmd" file can someone help me with this.
    Thnx!
  12. #264
    Jan 2019
    Quote Originally Posted by DieselManiac View Post
    Thnx!
    Hello there.
    I send you PM.
    Cheers...
  13. #265
    Oct 2011
    Germany
    Thnx!
    these lines are the keygenerator.cmd, copy the text to a new file,
    name it "keygenerator.cmd"
    @@Echo Off
    cls
    Set T=%Time%
    Set "FileIn=Key"
    Set "FileOut=KeyFile.bin"
    Set /A Max=611249
    If Not Exist "%FileIn%" (Echo !!! File "%FileIn%" not found &Pause &Exit /B 2)
    Set /A @@01=2, @@02=4, @@03=8, @@04=16, @@05=32, @@06=64, @@07=128, @@08=256, @@09=512, @@10=1024, @@11=2048, @@12=4096, @@13=8192, @@14=16384, @@15=32768, @@16=65536, @@17=131072, @@18=262144, @@19=524288, @@20=1048576, @@21=2097152
    Set /A Min=0
    Set "Var="
    Set "All="
    Set /A Re=%Max%
    :Begin
    Set /A Re=%Re%-%Min%
    Set "All=%Var% %All%
    If %Re% LSS 2 GoTo :Continue
    FOR /F "usebackq tokens=1,2 delims==" %%i IN (`Set "@@"`) DO (
    If %%j GTR %Re% GoTo :Begin
    Set /A Min=%%j
    Set "Var=%%j"
    :Continue
    Call :double "%FileIn%" "%FileOut%" %Re% %All%
    del Key~tmp1
    del Key~tmp2
    Echo "KeyFile.bin" done
    Echo Powered by SVVAG2000
    Pause
    GoTo :Eof
    :double
    Copy /B %1 "%~1~tmp1" >nul
    Copy /B %1 "%~1~tmp2" >nul
    > %2 (cd.)
    If %3 EQU 1 Copy /B %1 %2 >nul
    Set /A i=1
    :Beg1
    Set /A i=2*i
    Copy /B "%~1~tmp2"+"%~1~tmp1" "%~1~tmp2" >nul
    Copy /B "%~1~tmp2" "%~1~tmp1" >nul
    If %i% NEQ %4 GoTo :Beg1
    Copy /B %2+"%~1~tmp2" %2 >nul
    Shift /4
    If Not "%4"=="" GoTo :Beg1
    GoTo :Eof
  14. The Following 25 Users Say Thank You to bergbahn For This Useful Post:
    a17h641a (27th February, 2023), Ayhan86 (28th April, 2023), ayllon308 (12th November, 2022), ben1974 (18th February, 2022), bendy (3rd November, 2019), Brice59 (17th February, 2020), Carl (1st February, 2024), dmerkovic (30th July, 2023), Dodo123 (21st August, 2019), Doze (4th February, 2022), jsdias (7th July, 2022), koke (25th October, 2021), laki23 (15th August, 2022), lanefi (8th December, 2020), lupus80 (26th March, 2020), mafia69 (12th December, 2020), maxxy (20th April, 2021), newuser38 (7th April, 2021), NitroTarget (28th July, 2021), parys010 (8th November, 2023), Pyromain (6th June, 2023), radioman (25th April, 2021), silver25 (7th July, 2021), titanw (19th July, 2022), YASS59 (22nd June, 2020)
  15. #266
    Apr 2019
    Hey guys, May I know how can I access all these files?
    I am not able to access the link :
    https://www.digital-kaos.co.uk/forum...=1#post3607373
    Could anyone give me a hand, please?
  16. The Following 2 Users Say Thank You to siriusx For This Useful Post:
    Manos0100 (6th October, 2023)
  17. #267
    Jan 2019
    Quote Originally Posted by siriusx View Post
    What files do you need?
    Send me PM
  18. The Following 4 Users Say Thank You to boxsport For This Useful Post:
    anillilhann (16th May, 2020), siriusx (19th August, 2019), Zanter (28th May, 2022)
  19. #268
    Jun 2013
    EU
    I am bored of all this sh1t.
    Here easy way to recover your kess 5.017 SD Card.
    Just put fat32 formatted SD card into kess, decompress the files provided HERE in the ksuite update folder, plug kess and start ksuite. SD will be made from scratch effortless. No need any tool cracked or not, no need any other file, no need know SD CID, no need HEX experience,...etc, just need computer, kess and sd card with this update pack.
    Pass in PM after have given thx and rep to this post.
    Download files HERE.
    Regards,
    Edit: PASS you can find on first post of this thread.
  20. The Following 289 Users Say Thank You to morgano For This Useful Post:
    2xded (10th January, 2020), a17h641a (7th October, 2022), AchilleGR (18th September, 2019), afmotorchips (20th February, 2021), ahadi (23rd September, 2019), akiramo (14th November, 2022), albertoak (15th August, 2020), alexandrlukash2 (13th January, 2023), altackbar (19th September, 2019), AndryMG (1st August, 2022), AngelDGS (28th April, 2023), angelito20 (20th September, 2022), anillilhann (16th May, 2020), anonimusxx (15th October, 2023), aqemqum10 (20th March, 2020), Araiy0 (4th October, 2019), arejas (7th November, 2019), artkiani (29th August, 2021), autocar88 (14th June, 2020), Avega1984 (19th January, 2020), Ayhan86 (14th February, 2023), ayllon308 (20th February, 2023), BackoVDV (18th June, 2020), bazaa (14th August, 2019), beckraika (11th January, 2020), bergbahn (12th August, 2019), bigbang63 (10th February, 2020), bigchev502 (27th May, 2022), biwie (4th February, 2020), bmwmds (1st March, 2023), Bmwpower530 (21st December, 2020), bolt1502 (16th March, 2020), boolero (24th September, 2021), boringbob (30th October, 2019), boxsport (26th September, 2022), braco046 (16th June, 2020), branci2008 (23rd July, 2023), Bridlore (6th February, 2024), bubasior (2nd March, 2022), Burnsi (2nd January, 2020), burpod (21st June, 2022), caja88 (28th September, 2019), CaptMurica (14th December, 2020), Carl (1st February, 2024), carxservice (28th February, 2023), chaltura1 (6th August, 2021), chentron (6th November, 2019), chicotecni (11th October, 2019), CiccioBullet (5th April, 2020), cieelak (1st October, 2021), cntgfysxjaw (5th April, 2020), cosmynnec (10th September, 2019), coubi (25th January, 2021), crouchinggerbil (25th September, 2020), cryan1155 (19th October, 2019), csaky (26th September, 2022), Cyrez (5th September, 2019), dailyT (10th December, 2021), daniboy (30th July, 2020), danielnif (14th July, 2021), dannyx5321 (19th October, 2019), dEONBE (23rd September, 2021), derce (19th July, 2020), DiegoAC (16th January, 2020), DieselManiac (12th August, 2019), dimisx1 (13th November, 2022), dimo (9th June, 2022), dlenk (20th September, 2023), dmerkovic (30th July, 2023), dob12 (17th January, 2021), Dodo123 (21st August, 2019), doingthedoings (25th January, 2023), dougydoug (26th December, 2019), DUCASBK (18th September, 2019), duckstar (23rd March, 2022), Duke27 (8th September, 2019), edward88 (11th January, 2020), elc (3rd September, 2021), electronistul21 (23rd December, 2022), eueuu (1st November, 2023), Fabry73 (5th December, 2022), filip98 (14th November, 2019), francsss (22nd October, 2022), funthomas (15th September, 2019), gabi22 (29th June, 2020), gandziak (24th September, 2019), gas43 (12th August, 2019), Gaxal (29th October, 2023), got (23rd November, 2019), gyapi11 (27th September, 2019), gyroplane (31st August, 2023), Hawana (6th December, 2019), henriquekc (13th April, 2020), homeless (20th November, 2023), hong6110 (21st March, 2023), Id82 (8th September, 2022), ikillyou983 (19th November, 2021), ilen (7th June, 2020), ilgrisu (15th February, 2023), ionutkep (7th February, 2021), jacuna (17th October, 2019), jimbodesbois (14th November, 2021), jjmotor (23rd October, 2020), jlfalagan (10th December, 2023), jmorek (28th February, 2021), jojo1952 (30th January, 2020), judebanane (23rd August, 2022), JuhnuAW (28th April, 2022), kaits (6th September, 2019), kapadokya (5th September, 2022), karim1630 (30th July, 2021), karmoranas (20th February, 2022), kaw (17th November, 2019), kev bmw (14th January, 2020), knowme2k (18th May, 2021), koke (24th October, 2021), koko954 (25th October, 2022), kolikotoga (16th September, 2020), konq100 (21st May, 2020), kostas (7th November, 2019), krae (1st February, 2020), krisjanis (24th September, 2019), kuchka (11th August, 2021), LacoBL (14th November, 2019), laki23 (5th January, 2021), lanefi (8th December, 2020), levien (20th March, 2024), licorne2 (11th September, 2019), lokey123 (7th October, 2021), loskani (14th September, 2019), Luis73 (20th September, 2019), maciej77 (31st October, 2019), madbg (10th September, 2019), mailzaforume77 (19th June, 2020), maku1977 (17th August, 2019), Manos0100 (6th October, 2023), mapixi (9th November, 2023), Mario6 (9th September, 2019), marius7592 (6th March, 2024), Martello77 (29th August, 2022), maxcoff (17th September, 2019), maxxy (19th April, 2021), Mayoboomin (23rd October, 2023), MAYQUAD (2nd January, 2020), mclarenax (2nd September, 2019), mentos7 (13th May, 2023), mkii (1st August, 2021), mmauto (24th April, 2023), MOBILTRONIC (4th November, 2022), mrpurple (7th November, 2020), naemcl (28th September, 2019), namdilinh (24th October, 2019), newuser38 (7th April, 2021), niboelectronic (6th April, 2021), nici (22nd November, 2019), nick4jc (24th November, 2020), nitronick (7th September, 2019), norishor (26th October, 2019), otoemek (19th July, 2022), over73 (2nd October, 2019), p38 (5th January, 2024), paolo poppi (3rd February, 2020), pasthor (30th September, 2019), patolini (21st August, 2019), pawel107 (1st November, 2021), peechie (25th March, 2020), pem1 (31st December, 2021), pestinha29 (1st September, 2019), peter1977 (30th August, 2019), peter21 (26th August, 2019), PierreTheron (11th October, 2021), pinopino (26th August, 2019), pinotec (27th November, 2020), piramida (8th February, 2021), pocinas (13th August, 2019), Populin (14th May, 2020), POWER PLAY (26th January, 2020), powerelectricpl (19th July, 2021), pribi (30th October, 2023), puma2451 (24th April, 2020), pvroman (27th April, 2023), qni666 (25th March, 2021), quetinho (19th April, 2020), R0land (25th March, 2020), r3aperx (30th April, 2021), raben785 (1st September, 2019), radeen (1st February, 2024), raductn (25th December, 2020), rafal (20th October, 2022), rafik24 (19th April, 2023), Rafik89 (14th November, 2021), RAIONEJB (2nd April, 2022), redha503 (17th October, 2021), rejovi (6th April, 2023), Renoturbina (16th April, 2020), ricardoadami (20th February, 2023), Richi777 (9th July, 2020), Rider667 (31st January, 2022), rjpc (23rd July, 2022), rlmnt (12th March, 2022), robert1905 (24th June, 2023), Roberto 77 (28th November, 2019), rodf (30th July, 2021), roi3132 (8th April, 2020), Rolik (16th September, 2019), Rome125 (31st January, 2023), ROMIKUS (10th March, 2020), romrs (16th February, 2023), rs2000h (24th January, 2021), Ruatis (15th September, 2019), sakin (11th October, 2023), salimane (5th February, 2021), SANTI-MECCANICA (18th March, 2020), sbloem (10th January, 2022), scummy (18th September, 2019), segal75 (22nd November, 2023), Sergbolsh (1st February, 2020), serk120 (29th August, 2019), servaldsl (30th August, 2023), sghairdiag (3rd November, 2020), sharpshooter86 (3rd July, 2022), sherl645 (6th February, 2020), silver25 (7th July, 2021), Silver740 (29th January, 2021), siriusx (19th August, 2019), skystar (8th February, 2020), Slav1984 (15th June, 2020), slavisa988 (15th December, 2021), sm1l3 (16th August, 2019), Smarath (1st March, 2023), solcar (2nd December, 2022), Som3astar (18th August, 2019), srs55 (22nd May, 2022), stanpiotr (8th June, 2020), Strashila (20th June, 2023), talazso (9th November, 2023), Tanapat (9th February, 2023), taters (1st February, 2021), teejay1794 (18th September, 2019), Tgarnxx (15th October, 2019), Thagang (16th September, 2020), TheDevil667 (19th August, 2020), titanw (19th July, 2022), titinou67 (17th December, 2019), tkmmazda (13th August, 2019), tobiazz (4th July, 2020), Tomate (8th June, 2020), Torpedo1996 (6th September, 2023), toto11 (11th February, 2023), Totonio (27th December, 2022), trauss (12th December, 2019), TRXBoy (20th August, 2019), turbo16v (30th November, 2022), Vexred (7th August, 2022), vilin (5th August, 2020), Vladimir75 (27th December, 2023), volodin69 (31st July, 2021), Voron (19th September, 2019), vyoinlove (10th April, 2020), willy099 (6th February, 2020), wld5555 (2nd September, 2019), woekede (14th August, 2023), wongtukul (13th October, 2023), Xcat2008 (22nd August, 2022), XiperV (15th October, 2022), YOYOMARTIN2003 (7th August, 2020), zoro1 (8th November, 2019), zsolt162 (5th January, 2023), zvonimir04 (19th March, 2022), ZvonimirG (29th November, 2019)
  21. #269
    Jul 2019
    Are the .MYG/.FPF/.MOD files transferred to slave encrypted with XOR? I get that the underlying SD card and all of its contents are XOR encrypted, but after you decrypt it following the methods here, are the .PRT/.CRP files encrypted with another layer or no?
  22. The Following User Says Thank You to MuffinFlavored For This Useful Post:
  23. #270
    Feb 2017
    Netherlands
    I'm interested in this, do you also have te file to use this method on Ktag 7.020.
    And would like to receive your password.
    Thnx!
