Page 2 of 64 FirstFirst 12345671252 ... LastLast
Results 16 to 30 of 958
  1. #16
    Oct 2011
    Germany
    Quote Originally Posted by mrwolfie View Post
    Like this?
    Look at the files
    Mrwolfie key.txt is for the most China Kess5.017 SD-card
  2. The Following 2 Users Say Thank You to bergbahn For This Useful Post:
    Jose Santana (22nd April, 2019), Ramtamtam (18th June, 2021)
  3. #17
    Dec 2018
    Netherlands
  4. #18
    Dec 2018
    Netherlands
    Files are now on the sd card. do i need to encrypt the file again? if i put it in the kess, turn it on it says EEFFACE error
  5. #19
    Oct 2011
    Germany
    You must first decode your original SD so that you can read it.
    that should look like this:
    00000000h: EB 3C 90 4D 53 44 4F 53 35 2E 30 00 02 40 08 00; Ã~ <MSDOS5.0 .. @ ..
    00000010h: 02 00 02 00 00 F0 F4 00 3F 00 FF 00 00 00 00 00; .....?. à ° A '. ÿ .....
    00000020h: 00 A0 3A 00 00 00 29 A5 C6 CF 51 4E 4F 20 4C 41; , : ...) ¥ Ã † Ã QNO LA
    00000030h: 42 45 4C 20 20 20 46 41 54 31 36 20 20 20 00 00; BEL FAT16.
    Integrate the image as a virtual drive or copy it to a SD-card,
    then copy the folders and files to your new FAT 16 formatted SD and then encrypt them again with the new KEY.
    every SD-Card has it own KEY
  6. The Following 2 Users Say Thank You to bergbahn For This Useful Post:
    mrwolfie (16th January, 2019), Ramtamtam (18th June, 2021)
  7. #20
    Dec 2018
    Netherlands
    If you've done it before its maybe easy?
    I never worked with hex.. never worked with a sd card...
    Your tutorial is missing alot of info.
    the img file i created looks like this
    00000000 EB 3C 90 4D 53 44 4F 53 35 2E 30 00 02 40 02 00 ë< MSDOS5.0 @
    00000010 02 00 02 00 00 F8 EF 00 3F 00 FF 00 00 00 00 00 øï ? ÿ
    00000020 00 B0 3B 00 80 00 29 31 FA BE B8 4E 4F 20 4E 41 °; € )1ú¾¸NO NA
    00000030 4D 45 20 5F 31 32 46 41 54 31 36 20 20 20 33 C9 ME _12FAT16 3É
    I formatted the sd card into fat, copy the files into sd card, should be 4 maps? (file, log, system and update?)
    Crypted it with the tool and wrote the .img back on the sd card. still can read the sd card shows just alot of folders.
    When i insert the sd card into the kess it says EEFFACE error.
    you say i have to encrypt them again with NEW KEY? what is the key of it? is it the CID? the 13 lines we copyed?
    Edit:
    In your tut you say uncrypt and decrypt its the same thing right?
    So first make it readable, edit with hex first lines into :
    Then read the file, have alot of weird folders in it...
    Copy them?
    format sd card and put the files back in the sd card
    Use xorfiles to crypt the file again and write the .img file into the sd card again?
  8. #21
    Oct 2011
    Germany
    @mrwolfie
    Sorry that a lot of information is missing in my manual and that I have published my manual.
    If I had known that I only confused people, I would not have written them.
    in my manual is written:
    "then the start same Procedur to create a new “SD128 MB XOR Key01-13.img” file with new SDCard
    Key."
  9. The Following User Says Thank You to bergbahn For This Useful Post:
    karol123 (17th January, 2019)
  10. #22
    Newbie forever85's Avatar
    Jan 2019
    Italy
    This guide is present online, even the file is identical :-)
    Chip tuning professional.
    Winols original 4.30.
    File processing, DTC, DPF and EGR off.
    PCB Kess 5028, Ktag 8000.
    Optimized SD Card files for any SD card CID
  11. #23
    Oct 2011
    Germany
    delete delete
  12. #24
    Digital Under's Avatar
    Oct 2017
    mate, you make great tutorial
  13. The Following User Says Thank You to Digital Under For This Useful Post:
    bergbahn (17th January, 2019)
  14. #25
    Oct 2017
    Quote Originally Posted by forever85 View Post
    please link on guide
    i think you beeg trol
  15. The Following User Says Thank You to Digital Under For This Useful Post:
    bergbahn (18th January, 2019)
  16. #26
    Jul 2016
    Quote Originally Posted by bergbahn View Post
    @mrwolfie
    Key."
    The tutorial works 100%. I made a new card. I used 8gb and everything works fine. Thanks man.
  17. The Following User Says Thank You to karol123 For This Useful Post:
  18. #27
    Dec 2018
    Netherlands
    I never said its not working.
    I asked if he can add some more info that a noob like me can do it
  19. #28
    Oct 2011
    Germany
    I have a request to all, can you complete my guide to make it easier to understand?
    just post all tips here
  20. The Following User Says Thank You to bergbahn For This Useful Post:
    mrwolfie (18th January, 2019)
  21. #29
    Oct 2017
    on youtube i found this
  22. The Following 8 Users Say Thank You to Digital Under For This Useful Post:
    bergbahn (18th January, 2019), darka7 (9th March, 2019), Ecuhgvn (23rd July, 2021), Jose Santana (22nd April, 2019), Krittanu (14th August, 2020), mrwolfie (18th January, 2019), nbtechnic (8th May, 2022), radioman (19th November, 2020)
  23. #30
    Dec 2018
    Netherlands
    Any got the file, keyfilegenerator.cmd?
  24. The Following User Says Thank You to mrwolfie For This Useful Post:
