Page 30 of 64 FirstFirst ... 20252627282930313233343540 ... LastLast
Results 436 to 450 of 959
  1. #436
    Aug 2013
    Hi, can how to get keyFileGenerator.cmd? Besides, why keep display WAKE UP ERROR.. So annoying...
  2. #437
    Nov 2015
    CH
    Quote Originally Posted by Digital Under View Post
    thanks, Morgano
    i also added same archive for kreating sdcard Ktag 7.020
    SDcard Ktag 7.020
    just extract files in UPDATE folder
    pass= thanks+rep
    Hi Pass Please
  3. #438
    Jan 2019
    Somewhere between Continents
    Quote Originally Posted by kiongtt View Post
    check your PM.
    hope it helps.
    Cheers
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  4. #439
    Aug 2013
    Thank boxsport for the file. But end up with no luck. Now Showing "Protocol not found".. I am using Kess V2 5.017 Red PCB. Any suggestion Thank you..
  5. #440
    Jan 2019
    Did you made good sd card?
    Try to remove sd card and clean both contacts and put back in again...
    Do you have protocols active? Or are they grey?
  6. #441
    Aug 2013
    Thanks Boxsport.
    Yup I even using the file given by morgano still same "Protocol Not Found"
    I have try every method still same. Protocols is active I can go in and choose vehicle type but one choose it said "Protocols Not Found"2.jpg1.jpg1.jpg
  7. #442
    Jan 2019
    Don't know why it's showing you this, but try to do again sd card.
    I send you pm (see if it helps)
    If it doesn't work, i would assume there might be something wrong with your pcb...
    Have you reworked your pbc?
  8. #443
    Jan 2019
    Украина, Киев
    can i have a password for archive?
  9. #444
    Jan 2019
    Best Country of the world, GR
    Thanks Boxsport.
    Try another usb cable to kess (usb to printer)...
  10. #445
    Nov 2019
    Egypt
    Default thanksssss
    Quote Originally Posted by morgano View Post
    I am bored of all this sh1t.
    Here easy way to recover your kess 5.017 SD Card.
    Just put fat32 formatted SD card into kess, decompress the files provided HERE in the ksuite update folder, plug kess and start ksuite. SD will be made from scratch effortless. No need any tool cracked or not, no need any other file, no need know SD CID, no need HEX experience,...etc, just need computer, kess and sd card with this update pack.
    Pass in PM after have given thx and rep to this post.
    Download files HERE.
    Regards,
    thankssssss
    thanks everone
    and thanks morgano
    my kess is work
    hany mostafa
  11. The Following 3 Users Say Thank You to hany50 For This Useful Post:
    ericfp3 (11th December, 2019), morgano (8th December, 2019), zoki21 (3rd March, 2020)
  12. #446
    Mar 2017
    Quote Originally Posted by mclarenax View Post
    Hello. Thanks. pass please
    hello . thanks. pass please
  13. #447
    Sep 2015
    KTag 7.020 SD
    Pass PM Please
  14. #448
    Dec 2019
    Regards,
    thanx you,password please.
  15. The Following User Says Thank You to trauss For This Useful Post:
    Gadjet555 (26th February, 2025)
  16. #449
    Oct 2011
    Germany
    password is in first post
  17. The Following User Says Thank You to bergbahn For This Useful Post:
    morgano (14th December, 2019)
  18. #450
    Nov 2019
    i'm searching for the ktag 7.020 SD image and for "KeyFileGenerator.cmd"...
    Can anybody help me out?
