Page 35 of 64 FirstFirst ... 25303132333435363738394045 ... LastLast
Results 511 to 525 of 960
  1. #511
    Jan 2019
    Somewhere between Continents
    Quote Originally Posted by betsesv View Post
    Is there a preferred size and speed for sd card apart from brand reliability?
    size i dont think it matter, but if you have 2gb / 4gb fast SD Card, it will be more than enough.
    About speed, i used Class 10 SD card (pretty sure Kess/Ktag dont work at that maximum speed)
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  2. The Following User Says Thank You to boxsport For This Useful Post:
    betsesv (31st January, 2020)
  3. #512
    Jan 2019
    Quote Originally Posted by rybenz View Post
    I also need password for SD Card ktag 7.020 clone red pcb please.
    Attachment 685908
    I always get this message, and I can't close ksuite application. I was replaced usb cable with a new one and was check usb driver, is no problem.
    Any advice?.
    hello there.
    i can help you with files for Ktag SD card, but for "old method" if you like.
    send me PM.
    Cheers
  4. The Following User Says Thank You to boxsport For This Useful Post:
    rybenz (29th January, 2020)
  5. #513
    Jan 2019
    Quote Originally Posted by POWER PLAY View Post
    Hy Sapuhin,can you me helpen with folder update for sd card ktag 7.020?��
    Same answer to you:
    send me PM.
    Cheers
  6. The Following User Says Thank You to boxsport For This Useful Post:
    POWER PLAY (29th January, 2020)
  7. #514
    Jan 2020
    maybe you can help with kessv2 after reading i have unrecovable eroor? maybe you know the solution ?
  8. #515
    Jan 2020
    I see from your signature that you have a reworked kess with 5.028 firmware.
    Works good?
    If the admins allow from Where you bought it?
  9. #516
    Jan 2020
    @boxsport
    Works good?
  10. #517
    Jan 2019
    @boxsport
    Works good?
    Hello there. I don't have 5.028.
    My kess is 5.017 reworked.
    I haven't tried the 5.028 SD card on my kess to see the results, but i want to give a try probably on the next week.
  11. The Following User Says Thank You to boxsport For This Useful Post:
    morgano (1st February, 2020)
  12. #518
    Dec 2012
    Germany
    Many Thankssss,good work
  13. #519
    Jun 2013
    EU
    Quote Originally Posted by boxsport View Post
    Guess you most probably end up with protocol mismatch errors but will be fun to try.
  14. The Following 2 Users Say Thank You to morgano For This Useful Post:
    bergbahn (1st February, 2020), boxsport (7th February, 2020)
  15. #520
    Oct 2011
    Germany
    Quote Originally Posted by morgano View Post
    If you want to test 5028 SD with 5017 NXP
    if you do it wrong " protocol not found " error
    if you do everything Right " invalid protocol file " error
    in any case you have no function
  16. The Following 3 Users Say Thank You to bergbahn For This Useful Post:
    boxsport (7th February, 2020), morgano (1st February, 2020), rejovi (6th April, 2023)
  17. #521
    Jun 2013
    EU
    Quote Originally Posted by bergbahn View Post
    As expected
  18. The Following User Says Thank You to morgano For This Useful Post:
    bergbahn (2nd February, 2020)
  19. #522
    Member mandriao's Avatar
    Oct 2016
    Brasil
    You put wrong info with the link, the way to get the password is not ~~~~ my eggs by pm, but read the post where the link was originally put and give thanks and reputation to the post. Collapsing my PM with send me pass only yeld to non receive password. If give thanks and rep to the post no need write pm, i automatically send pm with pass. write pm without have given rep and thanks the the post in page 18 ends up forgotten and deleted.
    Thanks morgano. Please password in PM.
  20. #523
    Jun 2019
    space released !!! forgives.
  21. #524
    Jul 2018
    italia sardegna
    naturalmente no condividi con gli altri vero?
  22. #525
    Jan 2019
    thanks for the "tip"....
    so i gess there is no point on testing it to...
    but just for the "fun" i might do that if i get some time to play with the SD Card...
    Thanks for sharing the results...
