boxsport (11th May, 2020)
Need help from the Experts here....
someone asked for help regarding the SD creation because he was having "Protocol Not found" for Kess Protocol #548 in particular...
So, i checked on my kess and i´m also having the same result...
Already tried connecting to a OBD bench pcb i have and i got the same result (see picture)
Does anyone know if this is a Kess Clone issue? or is it something with the SD or with Ksuite?
Can anyone try this also?
Its Kess OBD II Protocol #548
Just Consider helping Freely like I want to do...
Thanks and Rep are Always Welcome...
The same. Protokol not found. Firmware FW 569 is missing. This protocol is not even on the clones it sells car-prog. The protocol is missing on the SD card.
Yes, but as I wrote, I also have Kess from cp2010 and there is not protocol 548. Maybe kitnoos2002 would say something about it, but I don't know if he is on this forum.
boxsport (12th May, 2020)
Protocol 548 (FORD TRUCK FPT ENGINE BOSCH EDC7UC31 KLINE) is in file FL0569.prt.
Becose this file is not on SD, so message "Protocol not found".
KESS, KTAG decoding LOG files - solved.
Could 2gb Samsung work , cause my Kess v2 5017 came with 2gb sd !!
Thanks....
Dumm Question (Please dont judge me, i´m still learning):
I see that there is some "sequence" on the protocol files to create the SD card. Could this "protocol file" be added?
I know that Morgano (and i REALLY APPRECIATE HIS TIME AND HELP) already mention that these things happend because we use Ksuite Version that "should" not be intented to the 5.017 Kess Version, and that is why we see "protocols" that are not in this Kess Version...
But, what is the logic on having these "protocol" files using the "sequence numbering" and not having all of them? (is this because its clone?)
Guys, please dont judge for my questions... I´m still learning and its just some doubts i have and that i (would) like to discuss...
Cheers
If you find new protocol file for you version KESS then you can add it, otherwise it is very difficult to do it.
In Ksuite can edit protocols in database Device.s3d, for example with program "DB Browser (SQLite)".
Thank you, this was very helpfully
boxsport (14th May, 2020)
Just Repaired my Ktag 7.020 Sd card! Thanks to All that have Posted and Worked on this!! Where would we be Without you guys!!
password please . thank u
I upload ktag 7.020 decrypted.... NO PASSWORD FOR ALL MEMBER-->>> rep+thanks first please.
I can crypt for any sd card.....
ae86jb (3rd June, 2020), angmar (7th September, 2020), autocar88 (30th May, 2020), bangorlad2k5 (24th August, 2020), dEONBE (21st September, 2021), detti (24th July, 2020), dob12 (3rd January, 2021), Doell60 (4th February, 2022), ecoperformans (30th May, 2021), frappes (11th January, 2024), Gandalf2021 (26th May, 2021), ilen (30th May, 2020), jorgeromao (5th March, 2022), Jupiter199 (7th June, 2020), kolikotoga (16th September, 2020), kona4 (24th January, 2022), lanefi (8th December, 2020), laurent2 (7th January, 2023), MorseHan (24th February, 2021), parys010 (8th November, 2023), Pinguxo (26th May, 2020), Pyromain (6th June, 2023), rejovi (6th April, 2023), skiera (25th August, 2021), Slav1984 (9th November, 2020), smysh (27th May, 2021), Tomate (8th June, 2020), Torpedo1996 (6th September, 2023), Vexred (7th August, 2022), zazd (22nd January, 2021), zsolt162 (5th January, 2023)
