Page 56 of 62 FirstFirst ... 6465152535455565758596061 ... LastLast
Results 826 to 840 of 929
  1. #826
    Oct 2011
    Germany
    Quote Originally Posted by Phnman390 View Post
    Can i Get password please
    Here are five passwords, choose one !
    PASSWORD
    PassWord
    password
    PaSsWoRd
    pASSwORD
    As with any good forum, this one begins with post number 1 on page 1
    It doesn't hurt to hit the thanks button
  2. The Following 2 Users Say Thank You to bergbahn For This Useful Post:
    boxsport (7th May, 2022), Phnman390 (7th May, 2022)
  3. #827
    Mar 2022
    us
    [QUOTE=boxsport;3831212]Guys, for those who want to do the Ktag SD Card using the "old" method, i´m posting the decrypted files attached...
    for pass, send PM.
    Thanks + Rep are very much appreciated...
    I will try to answer quickly...
    @bergbahn can you update your initial post, or if you want, just move the file to 1st post.
    Cheers to All...[/Q
    Can i have pass
  4. #828
    Mar 2022
    us
    none worked
  5. #829
    Mar 2022
    us
    Ill take this one PASSWORD
  6. The Following User Says Thank You to Phnman390 For This Useful Post:
  7. #830
    nbtechnic's Avatar
    Jan 2016
    does this update have an influence on the software used with the kess? example: I have a kess 5017 with software 2.53/2.70, will it work?
  8. #831
    Oct 2011
    Germany
    Quote Originally Posted by nbtechnic View Post
    what update? This thread is about rebuilding a defective SD card
    "Kess 5.017 how to read SD card or create a new SD card"
  9. The Following User Says Thank You to bergbahn For This Useful Post:
    nbtechnic (8th May, 2022)
  10. #832
    nbtechnic's Avatar
    Jan 2016
    Quote Originally Posted by bergbahn View Post
    Ok thanks for your answer,
    I actually expressed myself badly.
    I meant does this not influence the apps that come with the kess? thanks
  11. #833
    nbtechnic's Avatar
    Jan 2016
    how to know if the card is out of service please or damaged? thank you
  12. The Following User Says Thank You to nbtechnic For This Useful Post:
  13. #834
    Dec 2013
    Default Thank you!!!!!!!!!!!!!!!!!
    Thank you!!!!!!
    Quote Originally Posted by morgano View Post
    I am bored of all this sh1t.
    Here easy way to recover your kess 5.017 SD Card.
    Just put fat32 formatted SD card into kess, decompress the files provided HERE in the ksuite update folder, plug kess and start ksuite. SD will be made from scratch effortless. No need any tool cracked or not, no need any other file, no need know SD CID, no need HEX experience,...etc, just need computer, kess and sd card with this update pack.
    Pass in PM after have given thx and rep to this post.
    Download files HERE.
    Regards,
    Edit: PASS you can find on first post of this thread.
  14. The Following User Says Thank You to fuszko For This Useful Post:
  15. #835
    Aug 2018
    thanks pass pls
  16. #836
    Jan 2013
    italia
    i have a solution to create sd in kess, very easy
    insert a formatted sd card in kess,
    go to the main folder of the ksuite software, delete the update folder and insert this folder as an attachment.
    connect kess to pc open ksuite and finish the writing process.
    done. thanks and rep = passw pm
  17. The Following 2 Users Say Thank You to lupus80 For This Useful Post:
    a17h641a (4th July, 2022), Paulo bill (4th July, 2022)
  18. #837
    Feb 2020
    Germany Baden Würtemberg
    blease haf you my a pss ? Thank You
  19. #838
    Feb 2020
  20. #839
    Feb 2020
    Tank you i need the pass
  21. #840
    Jan 2019
    Lisboa, Portugal
    Thanks bergbahn for the code. Clear and efficient. All the best to you.
  22. The Following User Says Thank You to jsdias For This Useful Post:
    bergbahn (7th July, 2022)
