Page 6 of 63 FirstFirst 12345678910111656 ... LastLast
Results 76 to 90 of 935
  1. #76
    Trstenik - Thun
    Everything was explained well!
  2. #77
    skywoker's Avatar
    May 2012
    ROMANIA
    Yes. And i tested myself. Work well.
    Trimis de pe al meu HTC One_M8 folosind Tapatalk
    <a href="https://www.evc.de/en/check_evc_license.asp?k=to5BfjHPlwobCIDYikhVnw%3d% 3d" target="_blank"><img src="https://www.evc.de/common/check_evc_license_image.asp?k=to5BfjHPlwobCIDYikhV nw%3d%3d"></a>
  3. #78
    Feb 2019
    can somone open: Kess 5017 New SD Vers3.pdf ?
    because i can't :S
  4. #79
    Oct 2011
    Germany
    Quote Originally Posted by KennyHa View Post
    because i can't :S
    You need PDF reader
    https://get.adobe.com/uk/reader/
  5. The Following User Says Thank You to bergbahn For This Useful Post:
    johncz (25th February, 2019)
  6. #80
    Feb 2019
    Quote Originally Posted by bergbahn View Post
    hi, thats not the issues.
    when i click on it i get this : you do not have permission to access this page
  7. #81
    Member Jerak's Avatar
    Jan 2011
    Canada
    I guess it is because you are still new to the forum.
    I am fairly new too and still can't get SD-cardfiles_and_Tool.set.
    I can get the others though.
  8. #82
    Jan 2011
    Canada
    I found HxD. It is a freeware alternate to WinHex.
    When you open the Tools>Open disk, make sure that you uncheck "Open as Readonly"
    Then you can do the "Fill selection" with all the 00h.
  9. #83
    May 2017
    Half success, managed today to make card, after several tryouts it worked for me but only for 1GB card, still trying 32GB or 16GB Fast card with no joy yet.
    Question is, what system format should I use for 32 GB as there is no option for FAT16, apparently up to 4Gb only, if formatted in FAT32 XOR crashing and gave me crypted "empty" file, when tried to add block manually as explained by someone before Kess gives me EEFACE error. Probably still doing something wrong, did anyone created 32GB card?
  10. #84
    Jan 2011
    Canada
    Quote Originally Posted by polariscon View Post
    You could use diskpart to turn your 32gb to a 4gb.
    See:
    https://www.instructables.com/id/For...T16-not-FAT32/
  11. The Following 2 Users Say Thank You to Jerak For This Useful Post:
    dmerkovic (21st March, 2019), polariscon (20th February, 2019)
  12. #85
    May 2017
    Ok sorted card, unfortunately both cards 1gb and semi 32gb still give error "wake up error" on my kess for Audi A6 3.0tdi BMK engine. Maybe little of topic but what else should I do, is there any option to check if card is done correctly, kess reads protocols and no errors there, shit happens only while reading ecu.
    Please help.
  13. #86
    Oct 2011
    Germany
    Please help.
    I have no idea if Audi A6 3.0tdi works with Kess 5017, but I would compare or replace the necessary Protocol files.
    The files are available for download online or in my 1 # post
  14. #87
    Feb 2019
    Someone can help, old SDcard is not working, I made a copy for a new 4GB but a program Kess "Protocol not found"
    Thanks you for help.
  15. #88
    Oct 2011
    Germany
    Quote Originally Posted by johncz View Post
    There are no protocol files on your image file, so Kess can not find any.
    Only 4 CVS and 3 CFG files on your Image.
  16. The Following User Says Thank You to bergbahn For This Useful Post:
  17. #89
    Feb 2019
    So img is bad? Img download from web. It is possible to upload a functional img sd card for kess 5.017.
    Thanks you.
  18. #90
    Jan 2011
    Canada
    Thanks you.
    You need to build your own from the files and directions in the first post.
    "SD-cardfiles and Tool.txt" is the link for the actual Kess_5.017 folder to put on your microSD.
    Edit: just to be clear, when you get to the step to copy over the files, just copy what is inside the Kess_5.017 folder.
    Kess wants to see \File, \Log, \System, \Update not \Kess_5.017
