[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
Jose Santana (22nd April, 2019)
joker01 (8th April, 2019)
I'm having 2 problems with sd 4gb:
- when I delete all the dump with winhex and start ksuite with the deleted sd I have "external exception eefface" if I restart ksuite twice the program starts.
I have the list of cars of normal color, but if I go into any car I have "protocol not found"
- now I remove sd from the kess and put it in the reader sd, I open winhex, I click F9 but I have an error (it tells me to format to access)
someone help me ....
thank you
I do not know how many problems you really have
maybe my PDF file will help you.
....If you want to use any new SD-Card in your Kess 5017, use Winhex to fill the SD-card with 00 .
put SD-card in Kess, power on Kess..... do not start Kess Software
....Format the new SD-card with FAT , copy Files to SD-card and crypt it with “XorFiles v1.0”....
Dzeepromer (15th August, 2022)
[QUOTE = morgano; 3547316] Leggi la CID del tuo sd e dimmi. [/ QUOTE]
cid of the new card or the old one ??
now I deleted all the new one with all 00 I put back in the kess without starting ksuite and reread cid ???
cid I read it at what address ???
sorry but I find it hard to understand and the translator sometimes doesn't help .....
Again Press F9 and choose SD CARD EDIT than---> EDIT---> Define block --- choose on top (look attached Photo) ---- BEGINNING OF FILE - 0 and END OF BLOCK 793FFFF Press OK
when I run this it creates a file of 121mb (124.160kb) .... is it correct ???
Just need a laptop with native SD card reader, not USB plugged one, and use this app to read the CID of the new SD.
https://mega.nz/#!XFgnwKbD!8gh0DEgxW...Pw_2SI-BE5iM0o
Regards,
morgano thank you for the help you are giving me.
I open readcid.exe, command prompt opens but does not read any sd card ...
I will try to change SD card and try again with the post guide ......
You need native sd reader connected directly to the pci bus, the usb readers not work for reading the cid.
no usb adapter ...... use direct sdcard adapter in the pc .....
BMWfan1983 (11th April, 2019)
If you are using a tower PC not a laptop i'm sorry to tell you 99% of the front side sd readers are plugged to an USB port in the PCB.
Use a laptop with native SD reader.
You can also use an android phone with an app to read SD data, included the CID.
https://www.appsapk.com/sd-tools/
joker01 (11th April, 2019)
03534453553034478061159f9b00e526
https://mega.nz/#!eVpGnaYD
Here your image.
Key to download in PM.
