Originally Posted by
pocinas
I would like share my INSTRUCTION because for me this Instruction from 1st post and archives SD-cardfiles and Tool.txt exacly file READMY and Vieo Creation microSD for KESS 5.017 and KTAG 7.020.mp4 with incomplete understanding because Video is in Russian Language and in Video Person use 128Mb card, but my card was 4GB so i was stuck in point 10 from READMY instuction, look below i MODIFIED READMY file and added more important infos
1. erase in zero new Memory SD CARD so Open Winhex press F9 - open SD CARD reader than press CTRL+L (EDIT---> fill disk Sector) and choose "00" press Ok and Confirm - Wait to Fill all sectors to SD CARD
2. insert SD CARD into device (KESS/KTAG), connect to PC and start Ksuite (the best with Internet Switch OFF/disabled), Try to Entry in Any Vehicle there should Grey Protocols
3. remove SD CARD from device (KESS/KTAG) and insert into PC/SD READER
4. open memory card in HEX-editor, Press F9 and open CARD SD AGAIN
5. copy/select block 000000D0 - 0000019F should 13 Lines and using CTRL+ SHIFT+N (EDIT--> COPY ALL---> INTO NEW FILE) save new file give name "Key"
6. place file "Key" in folder with "KeyFileGenerator.cmd" and start "KeyFileGenerator.cmd"
7. after work of a script you will receive new file "KeyFile.bin"
8. format SDcard in FAT (4Gb can Format to FAT/FAT32) Cards 8GB and more support NTFS, so dont sure how format Card to FAT if is Bigger than 8GB, so my recomendations is Using maximum 4Gb Micro SD Cards
9. copying folders from archive "Ksuite" or "Ktag" to formated sd card
10. make new SDcard image with Files in HEX-editor so
IMPORTANT
Again Press F9 and choose SD CARD EDIT than---> EDIT---> Define block --- choose on top (look attached Photo) ---- BEGINNING OF FILE - 0 and END OF BLOCK 793FFFF Press OK
than CTRL+ SHIFT+N (EDIT--> COPY ALL---> INTO NEW FILE) and Save new file like "decript_sd.img"
than you file should Created /received 128mb
if you not do Define Block 0-793FFFF you file will every time BIG how is you memory card (example 4GB which is too big using XOR)
11. start XorFiles.exe and choose you
filename 1 - KeyFile.bin
filename 2 - Decript_sd.img
filename 3 - Cript_NEW_SD.img - file which will be Genarated
START
12. use JUST Win32DiskImager to write 128mb file to your SD CARD
Some another programs like imageusb or Winhex to write image on you SD, dont sure can be work, but Win32DiskImager can quarantee Write IMAGE correclty to you SD
