Page 9 of 62 FirstFirst ... 45678910111213141959 ... LastLast
Results 121 to 135 of 929
  1. #121
    Apr 2019
    Quote Originally Posted by bergbahn View Post
    check your private Messages
    Can u pm me as well?
    Thanks mate
    從我的iPhone使用Tapatalk 發送
  2. #122
    joker01's Avatar
    Jan 2018
    Quote Originally Posted by pocinas View Post
    I would like share my INSTRUCTION because for me this Instruction from 1st post and archives SD-cardfiles and Tool.txt exacly file READMY and Vieo Creation microSD for KESS 5.017 and KTAG 7.020.mp4 with incomplete understanding because Video is in Russian Language and in Video Person use 128Mb card, but my card was 4GB so i was stuck in point 10 from READMY instuction, look below i MODIFIED READMY file and added more important infos
    1. erase in zero new Memory SD CARD so Open Winhex press F9 - open SD CARD reader than press CTRL+L (EDIT---> fill disk Sector) and choose "00" press Ok and Confirm - Wait to Fill all sectors to SD CARD
    2. insert SD CARD into device (KESS/KTAG), connect to PC and start Ksuite (the best with Internet Switch OFF/disabled), Try to Entry in Any Vehicle there should Grey Protocols
    3. remove SD CARD from device (KESS/KTAG) and insert into PC/SD READER
    4. open memory card in HEX-editor, Press F9 and open CARD SD AGAIN
    5. copy/select block 000000D0 - 0000019F should 13 Lines and using CTRL+ SHIFT+N (EDIT--> COPY ALL---> INTO NEW FILE) save new file give name "Key"
    6. place file "Key" in folder with "KeyFileGenerator.cmd" and start "KeyFileGenerator.cmd"
    7. after work of a script you will receive new file "KeyFile.bin"
    8. format SDcard in FAT (4Gb can Format to FAT/FAT32) Cards 8GB and more support NTFS, so dont sure how format Card to FAT if is Bigger than 8GB, so my recomendations is Using maximum 4Gb Micro SD Cards
    9. copying folders from archive "Ksuite" or "Ktag" to formated sd card
    10. make new SDcard image with Files in HEX-editor so
    IMPORTANT
    Again Press F9 and choose SD CARD EDIT than---> EDIT---> Define block --- choose on top (look attached Photo) ---- BEGINNING OF FILE - 0 and END OF BLOCK 793FFFF Press OK
    than CTRL+ SHIFT+N (EDIT--> COPY ALL---> INTO NEW FILE) and Save new file like "decript_sd.img"
    than you file should Created /received 128mb
    if you not do Define Block 0-793FFFF you file will every time BIG how is you memory card (example 4GB which is too big using XOR)
    11. start XorFiles.exe and choose you
    filename 1 - KeyFile.bin
    filename 2 - Decript_sd.img
    filename 3 - Cript_NEW_SD.img - file which will be Genarated
    START
    12. use JUST Win32DiskImager program to write 128mb IMAGE to your SD CARD
    Some another programs like imageusb or Winhex to write image on you SD, dont sure can be work, but Win32DiskImager can quarantee Write IMAGE correclty to you SD
    I'm using winhex ...... after I insert the sd card and select block 0D0-19F the window creates new file asks me for a file size ...... what size should the key have ???
    edit.......
    seen from the video should be 1kb
    [SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
  3. The Following User Says Thank You to joker01 For This Useful Post:
    Jose Santana (22nd April, 2019)
  4. #123
    Oct 2011
    Germany
    Quote Originally Posted by joker01 View Post
    208 Bytes
    13 lines x 16 characters = 208
  5. The Following User Says Thank You to bergbahn For This Useful Post:
    joker01 (8th April, 2019)
  6. #124
    joker01's Avatar
    Jan 2018
    I'm having 2 problems with sd 4gb:
    - when I delete all the dump with winhex and start ksuite with the deleted sd I have "external exception eefface" if I restart ksuite twice the program starts.
    I have the list of cars of normal color, but if I go into any car I have "protocol not found"
    - now I remove sd from the kess and put it in the reader sd, I open winhex, I click F9 but I have an error (it tells me to format to access)
    someone help me ....
    thank you
  7. #125
    Oct 2011
    Germany
    I'm having 2 Problems.....
    I do not know how many problems you really have
    maybe my PDF file will help you.
    ....If you want to use any new SD-Card in your Kess 5017, use Winhex to fill the SD-card with 00 .
    put SD-card in Kess, power on Kess.....
    do not start Kess Software
    ....Format the new SD-card with FAT , copy Files to SD-card and crypt it with “XorFiles v1.0”....
  8. #126
    Jun 2013
    EU
    thank you
    Read CID of your sd and tell me.
  9. The Following User Says Thank You to morgano For This Useful Post:
    Dzeepromer (15th August, 2022)
  10. #127
    joker01's Avatar
    Jan 2018
    [QUOTE = morgano; 3547316] Leggi la CID del tuo sd e dimmi. [/ QUOTE]
    cid of the new card or the old one ??
    now I deleted all the new one with all 00 I put back in the kess without starting ksuite and reread cid ???
    cid I read it at what address ???
    sorry but I find it hard to understand and the translator sometimes doesn't help .....
  11. #128
    joker01's Avatar
    Jan 2018
    when I run this it creates a file of 121mb (124.160kb) .... is it correct ???
  12. #129
    Jun 2013
    EU
    Just need a laptop with native SD card reader, not USB plugged one, and use this app to read the CID of the new SD.
    https://mega.nz/#!XFgnwKbD!8gh0DEgxW...Pw_2SI-BE5iM0o
    Regards,
  13. The Following 2 Users Say Thank You to morgano For This Useful Post:
    joker01 (10th April, 2019), salimscan (21st December, 2022)
  14. #130
    joker01's Avatar
    Jan 2018
    morgano thank you for the help you are giving me.
    I open readcid.exe, command prompt opens but does not read any sd card ...
    I will try to change SD card and try again with the post guide ......
  15. #131
    Jun 2013
    EU
    You need native sd reader connected directly to the pci bus, the usb readers not work for reading the cid.
  16. #132
    joker01's Avatar
    Jan 2018
    no usb adapter ...... use direct sdcard adapter in the pc .....
  17. The Following User Says Thank You to joker01 For This Useful Post:
    BMWfan1983 (11th April, 2019)
  18. #133
    Jun 2013
    EU
    If you are using a tower PC not a laptop i'm sorry to tell you 99% of the front side sd readers are plugged to an USB port in the PCB.
    Use a laptop with native SD reader.
    You can also use an android phone with an app to read SD data, included the CID.
    https://www.appsapk.com/sd-tools/
  19. The Following User Says Thank You to morgano For This Useful Post:
    joker01 (11th April, 2019)
  20. #134
    joker01's Avatar
    Jan 2018
    03534453553034478061159f9b00e526
  21. #135
    Jun 2013
    EU
    https://mega.nz/#!eVpGnaYD
    Here your image.
    Key to download in PM.
  22. The Following User Says Thank You to morgano For This Useful Post:
