    sdnatlst's Avatar
    Aug 2011
    England
    Default citroen nemo ( pre code ) with mvp pro possible?
    infoquest says it is automatic with Precode,
    i have no full access to infoquest forum so cannot ask on there, has anyone succeeded with citroen nemo precode and add key?
    i have smart aerial and smart dongle.
    It also has Type 1 and Type 2 in menu, i think delphi and magnarelli system, how to tell which is which?
    the user manual i have is american and doesnt even include citroen for assistance, thanks!
    newone's Avatar
    Oct 2016
    i do not have mvp but nemo is fiat based with delphi bsi and by 1-2 types maybe mean 8 or 10-16 smd on remote,mvp pro is very easy in use and promts to every step.
    sdnatlst's Avatar
    Aug 2011
    England
    yes it worked for me today, and when plugged into the car it did not even ask for type 1 or 2 type 2, it just connected and precoded key, and all working, even remote!
    very nice, but now i need a new FIAT tool without tokens because MVP uses 2 tokens
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by sdnatlst View Post
    As I know you have Lonsdor which can do this kind of job. Athough struggle sometimes.
  5. The Following User Says Thank You to p1et For This Useful Post:
    sdnatlst (8th January, 2019)
    sdnatlst's Avatar
    Aug 2011
    England
    yes pete, thanks,, i know it struggle sometimes, which i why i want a better solution, cannot afford to lock FIAT remotes / TP
    p1et's Avatar
    Oct 2013
    With lonsdor first try to read pin. If will read as '0000' then don't proceed to precode. If pin will be four normal digits, then precoding will be okay. This way you will not waste transponders because of trying
  8. The Following User Says Thank You to p1et For This Useful Post:
