Results 1 to 7 of 7
    miralem's Avatar
    Default Peugeot 307 2.0 RHR SID803 DPF+EGR+Stage1 PLEASE
    Can you help me with this, and what file to write for this, and what must be changer from hardware side when I write it down to ECU
    Thanks in advance!
    Bosna
    Here dpf and egr. Write MPC file as it is SID803 ECU.About tuning, that does not make sense for now, first you have to solved problem with dpf and egr.
    Good luck.
  3. The Following User Says Thank You to mvekaz For This Useful Post:
    miralem (9th January, 2019)
    miralem's Avatar
    Quote Originally Posted by mvekaz View Post
    Good luck.
    Thanks a lot neighbor!!! Will report back....
    I have made thanks, I dont see REP button
    miralem's Avatar
    Good luck.
    I have tried it, it does not work, still DPF and EGR DTCs, and cannot start the car, I had write it via ktag with no issues
    Bosna
    Car start when you write original file? If start, maybe chk is problem try with file in attach..
  7. The Following User Says Thank You to mvekaz For This Useful Post:
    miralem (14th January, 2019)
  8. #6
    miralem's Avatar
    Thank a lot car is working good right now
  9. #7
    Sep 2018
    Hello can i get the password for that working file ?
    thx
