Results 1 to 12 of 12
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Default Master 2005 precode data
    Hi. Can anyone tell correct precode data for pcf7946a remote key.
    Master vivaro etc.
    Tried add key with this ori data. Key not accepted.
    Than wrote key to dump. In dump added and later thougd diag i see its added and id. But car mot start.
    Than made key by dump,2 option or write back or learn obd.
    Learned obd this time key accepted but remote not work.
    https://imgur.com/a/5u7hjlr
    Bllinda's Avatar
    Baltic
    Uploud ....
    Ikelk uch'o damp'a
    today
    A topic that interests me
    Dec 2016
    Quote Originally Posted by drugowaz View Post
    Hi.
    Your key are programmed & registered in UCH ( start the van ) but is not programmed to RF function , pre-code is OK but RCF part of pcf7946 is virgin like new key !
    szengen's Avatar
    Jan 2017
    master is strange, I read avdi china code, ok, programming not, i've programmed sbb china, key too, maybe because of that unas cold,ok, ok, ok, programmed sbb, minus 7 degrees Celsius, approx
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Yes i verified about preode manualy and with programmer all precodes same. Also precode of new key was same. Dont know wheres the problem about rcf not work
    Su dampu viskas ok nes org raktas pilnai veikia.
    Sep 2016
    GB
    What pcb use? China or original 2 hand? China key problem! We change pcf7946 to one orig. Pcb make precoding and remote work fine and car start. With China pcb only car start--remote not work
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Anyone can confirm that cn keys not work? I doubt that all not work as saw clients with aftermarket keys
    lion0304's Avatar
    Oct 2014
    Chinese key work very good, i have no any problem. Here is config that i use Kangoo, Clio, Traffic, Master
    It use PCF7946 not 7947. One or 2 buttons
  9. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    rusevi91kk (15th February, 2019), triak88 (10th January, 2019)
  10. #9
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Well i see precode same as mine. Maye just bad key
  11. #10
    lion0304's Avatar
    Oct 2014
    Not exactly, see Remote section: RSK Low and Hi diffrent than yours
  12. The Following User Says Thank You to lion0304 For This Useful Post:
    drugowaz (10th January, 2019)
  13. #11
    szengen's Avatar
    Jan 2017
    you have no idea, that the key will not be saved by pcf ........ 46.47
  14. #12
    Bllinda's Avatar
    Baltic
    At you bcm.n1ar2.x70.c66a 2,plugs?
    Aš pas save radau tik vivaro damp'a ....
    today
