brother, upload the original file
Hi everyone, would someone please help me with a original dump from a 2007 honda accord, petrol motor, the problem is that i tried to change mileage but when i did it, the fuel gauge indicator stopped working, now it always shows “low fuel” and i forgot to do a recovery file before changing it. What info do you need? The chip part number is s93c66.
Thanks in advance.
Edit:
Here is the db link of the file i read and edited, but fuel gauge stopped working.
https://www.dropbox.com/s/m830ga6l7u...3c66%20ic?dl=0
EDIT 2:
The car is a
*Honda Accord SE 2007
*Petrol Motor
*2.4 L
*Automatic
*Left hand driver
*México
* 121,101 k.m. (75,248.67 Mi)
dash label.jpgIMG_2156.jpgF8667B1F-FCA2-4634-A4FF-F59022734496.jpgAEC8DDCC-443D-4587-8B76-AA9D0FBFC8CC.jpgAEC8DDCC-443D-4587-8B76-AA9D0FBFC8CC.jpg
Cluster-label: CB0816061 78100-SDA
just in case i've to say that i'm using Xtool x100 pad2 with its adapter to read/write eeprom, and i also have digiprog3 with same results.
I didn’t find how to attach the file, so i share my db link. I hope it works. Thanks
hi friend
Cazalvalf (11th January, 2019)
hi and thanks, i wrote your BIN file but now it seems to be worse, now my display it's empty, the "low fuel" led is off but the fuel gauge level indicator reminds "low". And the "open door" led now is in the wrong side. (driver's door is open, but passenger's door led on, when it is close). i'll write back the original bin file (with fuel gauge low indicator problem) and let you know if the display works after that.
anyone would please help me with an original bin file from a honda accord 2007 2.4L petrol motor?? s93c66 chip
this is how it looks after i wrote your bin file chocho02. thanks anyway chocho02
Need a hell of a lot more info than you are supplying. With what you posted you are wasting peoples time.
Miles or Km?
What country are you in? I assume it's a left hand drive?????
The engine size can make a difference.
Auto or manual.
Best to post pictures of the cluster including the labels on the back.
Please DO NOT PM me asking for help.
Post in the forum, that is what it is here for.
The car is a
*Petrol Motor
*2.4 L
*Automatic
*Left hand driver
*México
Pics in the first post. Just in case i've to say that i'm using Xtool x100 pad2 with its adapter to read/write eeprom, and i also have digiprog3 with same results. Please i hope someone can help me with an original and no corrupted bin file. thanks guys.
this are some bin files i've already tested without success. Please if you have an original 2007 accord 2.4L petrol motor file, let me know. Thank you.
Hello and thanks for asking. Yeah i'm pretty sure it's a 93c66.D5492AC1-69CD-4DEA-9ABE-3B73C05F8674.jpg [PIC DB LINK]
In my previous post, the file named "Eeprom accord 07 s93c66 ic low-fuel-problem lalo-pal_orig.txt" is my original cluster file, the problem is that fuel gauge indicator is always "low fuel" with yellow led on. Until now, i just got 2006 accord bin files, i'm looking for a 2007 accord file and wishing it will work correctly.
you think it might be the eeprom? i mean, how many read/write it can support? Today i'll go and buy a new eeprom 93c66, i'm gonna try again to write a dump. But if it doesn't work, i think i'll be forced to buy another dash D: i hope someone can share a 2007 accord 2.4L dumb before it. Anyway, thanks guys.
