here is view from inside...
TOYOTA HIACE 2002 / 2.5 D-4D ENGINE
where is the immo-box located ? seems to be hidden somewhere....
ENGINE = 2KD-FTV
ALL keys are lost
i bought a NEW key from dealer
i read with TMPRO2 :
Recognized as: Texas fixed
ID 4C - JMA TP02/TP07
TIRIS Data: 7E 80 DF 34 0B 00 00 00 00 54 B6 7E
so is there separate IMMO-BOX, or is all hardware inside the ECU ?
attach : the ECU-label and the 93C56 from ECU
is the "key data" inside this 93C56 , or there must be a separate IMMO-BOX ??
CARPARTS (10th January, 2019)
ejoyeux (15th October, 2020)
i found myself
here is working data for immo box ; i added the new key inside and engine start
I have same immobox with corrupted data. Can I use this file?
I'm in a all keys lost situation with my toyota hiace 2008 being stuck in very small mountain village.
After lot of research on internet here is what I would like to do:
Get new cutted keys from a Toyota dealer with my VIN. (done)
Get the immobox from my vehicle 89780-26141. (done)
Dump the information stored into 93LC66 eeprom. (done see attachement)
Now the idea from the information a gathered from internet is to virginize this eeprom and put it back into the vehicle to enter learn mode and reister the new keys from the ignition lock.
If it doesn't work I would like to do like you and get the key transponder code, I don't have the transponder code from new keys at the moment.
At least could you tell me how you put the new key transonder code into the dump ?
