Results 1 to 5 of 5
    Jan 2019
    Default Kess V2 Tuning and EDC17
    Hi everyone.
    I'm trying to write to a 2012 bmw x1 MT (EDC17CP02) using a kess V2.
    I can read the original file and i have sent this to a tuner, my problem is after writing the new file my car won't start.
    I'm able to write my original file back and the car starts fine but i'm not sure what the problem is here. Is it to do with the TPRO? and what can i do to combat this?
    If so, how are companies like bluefin superchips able to write via obd?
    Any help would be greatly appreciated
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Tprot, you have chanche the car start again and you are able to write ori file. Normaly you cannot write back ori file if you switch ignition off or try to start.
    Ik you do this with fgtech, he give a warning message do write ori back and not turn off ignition.
    Open ecu, read with tricore and all is ok.
    Bmw edc17 after 2008 have tprot for do this job over obd.
    Kess geniune have new protocol and read virtual and you write only cabiliration are of the flash. Then all is ok.
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
  3. The Following User Says Thank You to sdtsedat For This Useful Post:
    Michael91 (11th January, 2019)
    Jan 2019
    Switzerland
    Also no Problem with ktag.
    Sep 2016
    also no problem in kess, genuine kess.
    FILE SERVICE
    Jan 2019
    Thank you for the help everyone, I'm going to have a go at flashing via tricore
