read eeprom from ecu and post here ( 95160 )
I urgently need the help of a nice
and capable fellow human beings!
following problem, I have a Fiat Stilo
with nem (IAW 5NF.T9 Ecu)
the old one unfortunately went bad and
used bought, supposedly (immo off)
That's why I think about Ebau
unfortunately that was not the case!
Now my question, what do I need for that
or could someone give me instructions for that
thanks in advance!!!!
need help
now my goal is to buy xp-005
who will help?
jonny0815 (11th January, 2019)
would it also be possible to exchange the eeprom of the original?
if yes, which one would that be?
Thank you
ok, with which program do I read the data?
do I need a special adapter or is it about the com port?
thank you for your help!!
if I cut out the piece, can I then solder the eeprom from the original ecu?
u can swap eeprom from ori to donor without problem
need help
who will help?
jonny0815 (13th January, 2019)
Use fvdi.Read by obd.
I chose the second variant ....
will replace the EEPROM tomorrow.
I exchanged the eeprom. immo is active.
did I misunderstand what?
Hope this is the right one
here you go:
2 files----
1- off
2- for coding
pass pm
need help
who will help?
jonny0815 (20th January, 2019)
