Results 1 to 5 of 5
    Dec 2018
    Default Sprinter 2011 clean ?!
    Hello,
    I have a Mercedes Sprinter II with the SRS computer locked and fault "internal malfunction".
    I ordered a used calculator in which I loaded the original program through the ultraprog software.
    Nothing changes the calculator is always locked and defaults are always present.
    Could you send me a clean version so I can compare them
    Thank you
    Bosch 0 285 010 349
    Jul 2016
    Ukraine
    Hello. In these blocks, a Mercedes has the concept of an id, it needs to be written into a block in order to use someone else's. If in your dump the firmware with the id from this car is native, then try and report.pass in pm/
  3. The Following User Says Thank You to urametz For This Useful Post:
    vincent1995 (11th January, 2019)
    Dec 2018
    Thank you very much, I try this afternoon and keep you informed
    Why can not I download the file?
    Dec 2018
    I tried your file, the witness and always lit as well as the locked computer; however one of the default (9005) has disappeared
    What do you think I should do?
    Thank you
  6. #5
    Dec 2018
    Help Please
