Results 1 to 11 of 11
    Timisoara
    Default Ford FORD C-Max, 1.6 TDCI auto to manual conversion
    Hello
    ecu is 4M51 - 12A650 - PA 0 281 011 533
    what ecu part No flash wold be ok for manual conversion
    The car is working ok but in any gear after gear change engine automatically rising RPM
    thank you
    rafal's Avatar
    UK - PL
    4M51-12A650-NF will work ok
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following User Says Thank You to rafal For This Useful Post:
    clauberty (12th January, 2019)
    Timisoara
    Quote Originally Posted by rafal View Post
    do you have dump ?
    rafal's Avatar
    UK - PL
    sorry but not...........
    need help
    who will help?
    Timisoara
    how to convert PHF file to bin
    or what tool to use to be able to write this type of file
    Thank you
  7. The Following User Says Thank You to clauberty For This Useful Post:
    kilog (27th March, 2021)
  8. #6
    Timisoara
    I write this dump flash and MCU but same behavior
    Should i write EEP to? but i do not have
  9. The Following User Says Thank You to clauberty For This Useful Post:
    dukhovich (10th July, 2021)
  10. #7
    Senior Member smotorsport's Avatar
    Feb 2018
    EDC16C34? Post ori dump here, will try to help.
  11. #8
    Timisoara
    Quote Originally Posted by smotorsport View Post
    Hello
    attached and thank you
  12. #9
    Feb 2018
    Quote Originally Posted by clauberty View Post
    Hello
    Was the car with cvt transmission? Here test this switch only solution, if it doesnt work we will try to copy gearbx_rV high and low values from manual one... And if then no work, you'll have to copy eep from manual car too but dont know what to do with immo then...
  13. The Following User Says Thank You to smotorsport For This Useful Post:
    clauberty (19th January, 2019)
  14. #10
    Timisoara
    Hello
    car wont start with this mode
  15. #11
    Feb 2018
    Here, test again.
  16. The Following 2 Users Say Thank You to smotorsport For This Useful Post:
    clauberty (4th March, 2019), dukhovich (10th July, 2021)
