DPF functionality off
Can anyone assist with removing dpf
I have tried dpf remover without success
Hardware: 6429011600
SW Version: 0009040200 6429025402 6429031511
Calibration file: CR61-DDB5-212WA-642LS-EU6OPS_4x2_3S-ME09
Calibration: 6429031511
ECU: EDC17CP57
Denso, Transtron, Hitachi & aftermarket Standalone ECUS
kinketotua (15th January, 2019), konq100 (14th January, 2019), S.W.A.M.I (15th January, 2019), stanislav georgiev (16th January, 2019)
still limp mode .
you can try pass in PM!
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
DTC 1: P2002-
DTC 2: P244A-
second file same result
so an update to this.
I bought a file that worked for approx 1 month, now it is back
anyone have a solution for this ?
Do You reset DPF values on original soft in ECU before write DPF OFF file ?
faults cleared & reset before writing.
all values within normal range post writing
need EGR off also?
in this ecu never need reset dpf..... cut dpf, dtc + limp and works.
FILE SERVICE
update : still not solved
do you have adblue on this car?
If I helped you please remember to give thanks and rep. A little thanks goes a long way
