Results 1 to 7 of 7
    Portugal
    Default SID807 problem reading
    I to all. I have one ecu Sid807 with TC1797 from Ford Focus 1.6 Tdci 2011 and i try read with Ktag 7020 red pcb with Ksuite 2.23 and start ok but stop in 79% reading. Someone now what am I doing wrong to always give error to the 79%.
    Mar 2013
    Europe
    Which voltage adapter you use for ECU?
    Best is voltage regulator is that
    Portugal
    I use a regulator like that, and nothing. Stop in 79%
    Apr 2011
    Set the voltage 15v check the wires and connections with multimeter
    LG-H860 cihazımdan Tapatalk kullanılarak gönderildi
    Portugal
    I was told that there was a way to turn this Ktag into a KTM100 so I could read this Sid807. Can anyone help with this?
    Portugal
    Problem solved with Ktag 2.25. Software problem.
  7. The Following User Says Thank You to jolor For This Useful Post:
    hellmet (18th April, 2019)
    Nov 2012
    Did you install k suite 2.25 and so you solved the problem?
    2.23 no good?
