Results 1 to 14 of 14
    Jan 2019
    Default VW T4 2.5 TDI Immo off
    I have a ECU from a VW Transporter van that needs the immobiliser removing.
    ECU number: 074 906 018 B
    I have attached the files (flash and eeprom) if someone would be able to do it for me.
    I'm also willing to learn so if someone could provide a tutorial I'd be happy to do them myself.
    Thank you in advance!
    rafal's Avatar
    UK - PL
    what was done in car?
    pump changed?
    need help
    now my goal is to buy xp-005
    who will help?
    rafal's Avatar
    UK - PL
    if pump still same so eeprom is enough:
    need help
    who will help?
  4. The Following User Says Thank You to rafal For This Useful Post:
    Xylnx (13th January, 2019)
    Jan 2019
    I'm unsure, the vehicle is not mine.
    I'll ask for some clarification but I think it could be an issue with the transponder coil and the owner wanted an easier solution than changing the ignition barrel
    Jan 2019
    I've already tried with the EEPROM but it doesn't work. Would you be able to off the flash for me?
    Quote Originally Posted by rafal View Post
    pump changed?
    This is different engine like in audi. You can download EDC15 calcluator from: https://www.vagdashcom.de/html/download.html.
    If not work u have another problem not in immo. Engine start and stop or not running ?
    Here is your immo off file:
  8. The Following User Says Thank You to wojciech300 For This Useful Post:
  9. #7
    Jan 2019
    Quote Originally Posted by wojciech300 View Post
    Thank you for the info but looking on here and other forums it seems that EEPROM is not enough and the flash must be altered to fully remove the immobiliser?
    Is there anyone on here that would be able to help?
  10. #8
    rafal's Avatar
    UK - PL
    if pump still same so eeprom off must work ok
    make good diagnostic first..............
    need help
    who will help?
  11. #9
    Jan 2019
    Thank you rafal just been in contact with the owner and the pump has been changed
  12. #10
    In this car pump have nothing to immo! It is different engine like in Audi or Passat. You can change pump and car must start.
  13. The Following 2 Users Say Thank You to wojciech300 For This Useful Post:
    rafal (14th January, 2019), Xylnx (19th January, 2019)
  14. #11
    rafal's Avatar
    UK - PL
    Yes you have right.
    need help
    who will help?
  15. #12
    Jan 2019
    Confirmed working. Thank you very much everyone.
  16. The Following User Says Thank You to Xylnx For This Useful Post:
    rafal (19th January, 2019)
  17. #13
    stanislav georgiev's Avatar
    Oct 2014
    България
    I have the same problem, would you tell me if this decision I have made will work
  18. #14
    Oct 2014
    България
    Nobody wrote anything, but the solution worked
