I can turn it off.
Where are you from?
Hello. I have swapped vr5 0669006032a me7.1 into golf 2. I have some faults in ecu...
I can't found eskonf to do dtc off of these fualts. Can anyone help?
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
P1636 - 35-00 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
17834 - EVAP Purge Valve (N80): Open Circuit
P1426 - 35-00 - -
17841 - Secondary Air Pump Relay (J299): Open Circuit
P1433 - 35-00 - -
17840 - Secondary Air Injection Solenoid Valve (N112): Open Circuit
P1432 - 35-00 - -
17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit
P1118 - 35-00 - -
16525 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit Malfunction
P0141 - 35-00 - -
I can turn it off.
Where are you from?
From Poland. I'm doing codewords off but i dont know how disable them in eskonf. In me7.1 is different than me7.5...
What do you offer in return?
What can i do...
check adresse 10b70 or 71 there is esconf 13x1
8bit 2er system
than check here https://s4wiki.com/wiki/Tuning
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
I found it on 10b72. This is no sens. Thirst bit is CC and ev4 is off. 10b70 and 10b71 is 00 .On wiki 1 place on 1bit is sixth cylinder but i have 5 cylinders motor...
I don't even have to say "test".
It's my SWAP file. Flashed over 20 times.
first 2 DTC's can be fixed with codding. Last one needs "00"Code:18044 - Powertrain Data Bus: Missing Message from Airbag Controller P1636 - 35-00 - - 18057 - Powertrain Data Bus: Missing Message from ABS Controller P1649 - 35-00 - - 18058 - Powertrain Data Bus: Missing Message from Instrument Cluster P1650 - 35-00 - -
Ice is right - everything is in WIKI, but you must use brain.exe
DTC search procedure based on 066906032AG file:
DTC Error Code Class Table (8 bit table) 0x106E4
DTC Manufacturer P-codes (16 bits values) 0x14254
DTC CARB P-codes (16 bits values) 0x14694
For example, to find which error class goes with this code:
P1650 - 35-00 - -
In WinOLS, use the following view: 16 bits, LoHi, FF
Search for an hexadecimal value of 1650 in the first table.
Note: Since it's a Manufacturer P-Code, the error only appear in the first table
You will find 4 occurrences at the following addresses: 0x142E4, 0x142E6, 0x142E8, 0x142EA
Make the following calculation:
( addresses of the first occurrence - address of the associated DTC table) / 8 = index
( 0x142E4 - 0x14254 ) / 8 = 0x12
Now, 0x12 is the index of this DTC in the Error Code Class table.
Determine the address of the value to switch off the DTC
0x106E4 + 0x12 = 0x106F6
If you find my post helpful please hit Thanks button.
You can also hit Reputation button if you are kind enough.
I know how to disable them in dtc table but i would like to do it in eskonf. CAN is no problem.
what's the pass?
I can't extract these files for you
I think i get it. Yesterday i did myself and think that's all what i need. o2 is not pass but i think it's because ecu don't see first o2 on table. I have to check on car this.
