Results 1 to 12 of 12
    Jul 2012
    Slovakia
    Default Fiat Croma 1.9 jtd DTC limp mode
    Very unusual problem... Car goes for half a day totally okay, than throws P0091 and car goes in limp mode until you turn car and turn again....We already replaced all regulators, last option is also ecu to be faultx
    Can this fault be erased, but that wont be enough, because on this car there was made full dpf off with some ecusafe and we did not find the right problem because car was not showing all dtcs...
    So I please someone if can disable fault with LIMP mode off to try if it will be enough and maybe there will not be needed to replace ecu.
    sdtsedat's Avatar
    Jan 2015
    Belgium
    This is edc16 or edc15? Post full ecu id
    Verstuurd vanaf mijn SM-G960F met Tapatalk
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
    Jul 2012
    Slovakia
    edc16c39 1.9jtd 150hp
    51809652
    0281012148
    1037389120
    C19442 .
    29 10 2007
    EDC16C39
    mancioks's Avatar
    Feb 2017
    Germany
    The file you attached is stock, no dpf off there.
    If i helped, don't forget push thanks + rep
    Jul 2012
    Slovakia
    Used dpf was put on car and programmed to stock map. This is the only fault which came up... And with this map also limp mode cames... Can this limp mode be removed from file?
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    can be removed
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Nov 2009
    I think your problem is not related to ecu. You should check wiring. What diag tool are you using?
    Jul 2012
    Slovakia
    Please made it off if really possible
    Original file is attached. We replaced fuel regulator on pump and on rail, sensor on rail. Also replaced fuel pump in tank. Wires to regulator are fine, checked too.
    carmageddon's Avatar
    Apr 2010
    Italy
    high pressure pump faulty or too old diesel filter
    Jul 2012
    Slovakia
    Fuel filter also replaced... High pressure was replaced last year by the owner... And it did not solve problem... They are driving for a year and half like this
  11. #11
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Quote Originally Posted by pcbox View Post
    here should work
  12. The Following User Says Thank You to Ignasvw For This Useful Post:
    pcbox (15th January, 2019)
  13. #12
    Jul 2012
    Slovakia
    Works like it should!
    Ignas you are the best!!
