what car?
breakage of communication canclip 90%?
Hi all.
Maybe I put the wrong title last time so I'm hoping for better luck this time. Please help if you can.
Are there any recommendations for having a Bcm reprogrammed back to factory defaults in the UK? I don't think it'll need virginizing because it's going back on the car it came off. I broke it trying to update it with my Clip. I've ordered a Renolink in the mean time so that means I should be able to virginize a used one doesn't it?
Thanks in advance.
what car?
Hi.
It's a Scenic 3 1.6 dci. Yes the canclip error'd at 91%.
Thanks.
virgin bcm, and program canclip out code
familiar with this situation. and often fix after an unsuccessful reprog
steelcityuk (15th January, 2019)
Thanks for the info. I've ordered a Renolink so hopefully I'll be able to use that. Any idea why they go wrong?
renolink no program bcm.
take for canclip and out / incode
Sorry if I wasn't clear, I meant I'll try to use the Renolink to virginise the BCM then program with the canclip.
hello.yes,you can use Renolink to virginise the BCM and to program olso use renolink.
pin 8 bit where to get? from the dead do not get
Sorry I don't understand.
