Results 1 to 11 of 11
    sdnatlst's Avatar
    Aug 2011
    England
    Default 2004 citroen xsara picasso - how to get pin?
    Hi all, anyone help how i will get the PIN from OBD possible?
    2004 xsara picasso, 2 button remote key.
    MVP pro says it codes the key, but will not read the pin code
    is it eeprom job only to gain pin code?
    ghostrider72's Avatar
    Jul 2012
    UK
    SMOK toll can do that over OBD.
  3. The Following User Says Thank You to ghostrider72 For This Useful Post:
    sdnatlst (15th January, 2019)
    jodge's Avatar
    Mar 2017
    the easy way when you take out the ECU hard way when you take out the BSI
    or you can buy the pincode from the dealer
    or you can read from the ECU if the can lines are available (MVP not supported)
  5. The Following User Says Thank You to jodge For This Useful Post:
  6. #4
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by ghostrider72 View Post
    only when it's siemens and you need to do the ecu connections too, bcose the CAN lines are missing from the OBD socket
    sdnatlst's Avatar
    Aug 2011
    England
    thanks, i will have to try with OBD , i have Lonsdor tool too, i hope it works.
    i quoted very cheap for this job as such old car, didnt realise pin code was sometimes difficult for them
  8. #6
    Jul 2012
    UK
    Quote Originally Posted by jodge View Post
    Im pretty sure I’ve done few K-lines with Smok as well.
  9. #7
    Oct 2018
    Northern Ireland
    Looking at this too. I’ve sent for cables for TDB1000 to read pin from ECM without removal to see how it works out
  10. #8
    jodge's Avatar
    Mar 2017
    dunno
    it's from the support
    Peugeot/Citroen 2001-2006 SIEMENS (connect the CAN H and CAN L pins to the connector of the controller, see the photos in the "MANUAL" tab)
    The TDB using the same stuff
  11. #9
    Jul 2012
    UK
    dunno
    Or just buy newer multiplexer.
  12. #10
    p1et's Avatar
    Oct 2013
    Lonsdor (type 4)
  13. #11
    Jun 2013
    Like this one ? Siemens BSI 9642825280. Wouldn't give me anything when I tried to read by OBD.
