anyone ......?
i have this Rogue nissan came for a spare key , original key is : s180144106
i have a renewed key : s180144104
using OtosysIm600 which i tought it will take few seconds and the key will be done as usual.
i programmed the new key , the security lights flashes and all ok but refused to take original key again.
the remote works on new key and ignition is on , ( BUT THE KEY LIGHT ALWAYS ON ) on dashboard and car crancks only
DTC in ECU is , p161f : immobiliser
DTC in BCM is B2192: ID DISCORD BCM-ECM
i tried lonsdor the same problem new key goes in crancks only no start
i renewed original key tried learned always same problem.
i deleted the new key which was crancking only and reprogrammed it , same situation.
anyone have any clue what went wrong ? i also disconnected battery multiple times
The only place success comes before work is in the dictionary.
anyone ......?
nissan you program old key first
then new key
then close with first original as far as i remember
i believe thats why nissan put out a technical bulletin about this
can it be because the key i programmed is s180144104 , different number do this ?
or is it compatible with it
Chip is same in both keys. It should acxept but example button n9t work etc. But if it not accepts key its wring. Maybe unlock bad. Buy 2 new key and make akl.
Batery remove 1 hour. Reconect delete errors and that make prog
1 key enought
IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
aassfour (16th January, 2019)
i couldnt find another original s180144106 Rogue virgin key even dealer doesnt have one.
i ve renewed the one i had using MK3 and tried to reprogram them after leaving battery disconnected for 1 hour and deleted all DTC , still when i put the key on start butt , ignition stays off and at the end i hear 5 beeps. its not taking them
only solution get another BCM ECM and KEY from a donor car and put them in . hopefully that would work
Probsbly you need steering lock too
its a totally different car then nissan. after research this forum and many other forums , i ve found many has faced the same problem with no solution stated on Nissan Rogue 2014 2015 2016
Ive done rogue 2 days ago 2016
No problem. 1 minute job
eliaselias (16th January, 2019)
I've heard some people on facebook have ran into this issue with Rogues. Apparently sometimes adding a key can mess up the BCM if I remember correctly, even if dealer does it. Hope you you can get it sorted man.
yep, reports are some BCMs are bricked. It's definitely a defect with certain BCMs. Good luck getting a dealership to admit that and foot the cost of the bill though.
