Results 1 to 5 of 5
    Dec 2018
    Default Help in flash of ecu
    Hello
    Please i want to know if i can read a flash software from Renault clio 3 and pût in other ecu of other clio 3 without problem mean that read flash from one car and put in other similar same ecu
    radurotaru19's Avatar
    Nov 2018
    Romania
    Certainly you can reprogram another ecu and flash the original maps from your car. It really depends on what tool you are using. If you are swapping the ecu you should also pay attention at the imobiliser system.
    Sent from my SM-G950F using Tapatalk
    Dec 2018
    Yes the ecu is siemens sim32 clio 1.2 petrol so i read m'y flash by using the kess v2 clone red but hé can not read so i will try by ktag to read it actualy i have a friend have same car with same ecu i want to read his flash and pût it in m'y ecu . this is possible or not
    KARLOVE POŚLADY
    Hi!
    What kind of MCU, flash, eeprom inside?
    KARLOVE POŚLADY
    eeprom should be 95160
