Aquí un buen vertedero
si resolviste dime
gracias
pass thanks pm
Hi Guys
We did a renault clio mk4 mileage correction, Block ABS in flash and write mileage. New mileage(13,400 MILES) is written ok however the odometer does not count and mileage is frozen. Upon starting car there is an error battery discharging fault, wipers always on, dont go off, high beams dont work. Restore car to original flash with approximately 22,300 miles on it, same problems, odometer now counts but still battery discharging fault etc.
we have the original flash for the car, but not the eeprom. We have the eeprom from the clocks when the cars playing up(ino stupid, should have saved eeprom before changing mileage but didnt have SMOK to hand and no option on X-tool FOR EEPROM BUT ONLY FLASH)
This leads me to believe the dump in the clocks may be corrupted, or maybe the battery needs coding in as terminal was removed for 5 mins to try and reset car after flash written. is this something anyone has experience with or can confirm, or any experienced guys here that can check if the eeprom is corrupt(flash cannot be as was read before mileage change)
any help would be much appreciated
ORIGINAL FLASH + POTENTIALLY CORRUPT EEPROM ATTACHED
si resolviste dime
gracias
pass thanks pm
