Results 1 to 8 of 8
    DK Veteran labusas's Avatar
    Nov 2010
    Default Alfa 166 All keys losts, Blue box
    Hi, I have this setup with a blue immo box (no eeprom). I have ordered keys from dealer. What is the best tool to make car start? Or what soft can make immo Off? Thanks so much
    ECU Alfa Romeo 166 0281010989 536B1ACAM CM ecu immobilizer key chip set kit OEM / eBay
    https://www.ebay.co.uk/itm/ECU-Alfa-...1951%7Ciid%3A1
    Nov 2010
    Anyone can helP?
    drugowaz's Avatar
    Mar 2015
    Lithuania
    No immo off. Only virgin.
  4. The Following User Says Thank You to drugowaz For This Useful Post:
    labusas (16th January, 2019)
    Nov 2010
    Do you know Drugowaz if AVDI can program keys when orderd by VIN from a dealer? What other tool can make this job?
    p1et's Avatar
    Oct 2013
    If you have key from dealer you can program it no problem. But you need pin code also.
  7. The Following User Says Thank You to p1et For This Useful Post:
  8. #6
    Aug 2013
    Macedonia
    buy black immo box from alfa romeo 166 immo code 2
    make new keys
    make ecu virgin
    install everything in the car
    put ignition on 1 min
    and car will work again
  9. #7
    Nov 2010
    I see AVDI by abritus doesn't list 166 model. I'll try login as 156 tommorrow and attemp programming. I have a PIN as well
  10. #8
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by nenadgorgi View Post
    make new keys
    make ecu virgin
    I know this way of doing that in theory but could you please explain how to make ECU virgin? Is there an eeprom inside and if I read it someone can make it virgin for me then?
