Results 1 to 4 of 4
    Sep 2016
    Default DTC Remove Opel ME9.2
    Hi friends, an Opel car with following errors came to me, it has several errors,otherwise it runs fine,but always these errors:
    P0300
    P0305
    P0306
    If anyone an help here to remove them from flash will be great!
    Kic's Avatar
    EU
    Missfire on a Turbo V6 needs further investigation.
    Spark plugs? Coils? Bad injector?
    "Fixing" cars with DTC off (if all OEM components are present, eg. EGR, DPF...) should be a criminal offence!
  3. The Following User Says Thank You to Kic For This Useful Post:
    voltechcar (18th January, 2019)
    Sep 2016
    Yes thats right,but customer says everything is changed, car runs well he wants only check engine off
    Kic's Avatar
    EU
    No, it is not running well. Something is obviously faulty if ECU reports missfires.
    I know Opel drivers are cheap ( I am one ) but he needs to get to the bottom of
    this if he wants to have a peace of mind that his engine will not melt in the next few hundred KMs.
  6. The Following User Says Thank You to Kic For This Useful Post:
    quato79 (17th January, 2019)
