Page 4 of 4 FirstFirst 1234
Results 46 to 51 of 51
  1. #46
    Meat-Head's Avatar
    Quote Originally Posted by aidyk View Post
    absolutely no call for that yellow with brown tracer and red near that resistor at all. typical french i guess.
    but anyhow the previous posts and Meat-Heads pics there at the last were good help.
    cheers...
    1) Remember it's French the opposite to what you expect, but
    makes perfect sense when explained.
    ASSUMING the yellow/brown is for 2 reasons
    a) No reason, just to piss you off
    b) Vechiles fitted with 'climax control' electronic resistor
    2) Think about it, your some French bloke called Claude or Xavier, and
    you are making this car, you insert le resistor, clip, clunck, screw
    motor, plug, NEXT
    No plug, click, second plug for the resistor, same on the Clito
    3) Guess you resaerched this thread before you did the job?
  2. #47
    DK Veteran aidyk's Avatar
    europe
    yes i had a nosy before it came in, i wanted to order the parts etc and see what i needed, but i decided id drill the holes in resistor etc and solder on wires etc but as it happened it was only the 1 connection ( yellow/brown) that was making bad contact, so it just joined them up and it was grand.
  3. #48
    Jun 2009
    Banja Luka Ex Yugoslavia
    As i see , you guys do lot of A/Cs.
    But here is another problem by me.
    Here is second Renault with automatic A/C with no working blower motor.
    Motor ok , blower motor regulator ok, A/C control unit ok, i changed from other car.
    Diagnose say no tdc, in parameters i see PWM signal changing , but still no blower.
    By Renault VISU i checked every pin on ecu, but still nothing, on the bench i can check blower regulator with signal generator , but ecu can not. CAN signal missing.
    Any idea????????????
  4. #49
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    l have one of these in before xmas and it was the ignition switch , it was brought in because the switch/barrel locked and couldnt get key out . swapped it and started fine then customer said thats first time the fans worked in months ?
  5. #50
    Jun 2009
    Thanks for that , but i forget to mention,it is Megane II
  6. #51
    ...... but as it happened it was only the 1 connection ( yellow/brown) that was making bad contact, so it just joined them up and it was grand.
    Joining these wires only wont give a lasting solution, because the earth return for full speed also goes through the resistor. You will need to join the purple/brown wire directly onto the black wire that is returning to the motor, (but leaving the black wire connected to the resistor for speeds 1,2,3. The three smaller wires on the resistor are usually ok
