i only have this one
HW: AV21-12B684-HA
SW: AV21-12A650-HG
VIN nr.: WF0GXXGAJGARXXXX
SW ver.:
Spare:
Engine:
HW Ver.:
SW upg.: AV21-14C204-HG
Installation:
Guys could someone share a file for this Ecu (flash en eep).
First I tried with AT it failed to read it.
Then I read it with Gall (gen), first I get error on reading password, after adding white en purple cable it was able to find pw.
I read file, my soft man made a mod and write it back.
Now car don't start, I read eeen flash again and it looks like eep was changed.
I put ori eep back still the same,
Can someone tell me what their experience is with gall en this Ecu, I can't see any damage on the pcb, I did not bend pcb too bad.
Any idea? I have errors on injectors.
HW: AV21-12B684-HA
SW: AV21-12A650-HG
SW ver.:
Spare:
Engine:
HW Ver.:
Installation:
honingkoning (16th January, 2019)
1. AUTOTUNER not have in list ecu for FORD EDC17C10, only PSA(Citroen - Peugeot).
2. Fgtech original read/write ok EDC17C10 bootmode.
Check pcb from ecu, maybe you broke it when you opened... or one component like resistor or capacitor missing
Here you have full boot mode from one similar car read with fgtech.
TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
If I helped you please use button Thanks.
pike (16th January, 2019)
use ids and flashing again ecu, if immo is not destroy car starts.
FILE SERVICE
Errors on injectors, I would say pcb damaged.
