Tuning is done with EGR turned off. At present, I do not have a solution on DPF. You can try a second file, but I do not know if it will work properly.
fabcio52 (4th May, 2022), Helpmeplease196 (17th January, 2019)
Thank you, My DPF is empty
If DPF on does the regeneration still take place?
WinOLS (Audi A6 (TUNE + EGR_OFF + DPF_OFF) - 395437) .rar So you have found the solution, you are the best
This is the original of my BMW 535d with 272 hp, go there 330 hp, not disable DPF + EGR
1037390198.rar
Thank you
Not too much free help for beginning ? only 5 posts, first try to help other people here
I can screw and diagnose, for chiptuning I need your help
What can I help you help but without exaggeration. Someone makes files and someone else takes the money.
I can do everything but not for free.
fabcio52 (6th May, 2022), Helpmeplease196 (18th January, 2019)
Thanks, they are both my cars
FILE SERVICE 24/7
Stage 1 / 2 / 3 - DPF / FAP / EGR / SCR / NOx / TVA .. etc
Tools-Master: Autotuner / Flex / Trasdata / IO-Terminal / Launch Euro TAB II
Genuine software: WinOLS, ECM , tuning software etc ...
TECHSIX.NET - PLEASE BE CAREFUL THIS SCAMMER !!!!
http://www.techsix.net/
That was also very good what you did for my Audi, so I also asked about my BMW
FILE SERVICE 24/7
@ Oliva
the Audimod from 17th January, 2019 comes only up to 3000 rpm in 6th gear
Hello, a turbo hose was broken, I changed, now everything is fine, many, many thanks Oliva
please me send to password
