Results 1 to 8 of 8
    Jun 2012
    Default BMW E70 replace ecu+cas
    Hello everyone
    I have bmw x5 E70
    I change case3 + ecu + key
    my problem is that the gearbox does not work
    can someone help me to settle this
    thank you
    UK
    You need to reset egs isn, what was wrong with original dde/cas?
    Jun 2012
    hi
    Origin case is dead
    Try to read data from old cas and whrite to new one without changing the ecu
    UK
    As above, clone cas.
    You need to read ISN from EGS then write to the CAS and ECU and syncro all in if the CAS is not readable anymore.
    reproteq's Avatar
    en algún lugar de España
    hi
    i think you can copy config with comander and paste in new parts.
    i make this in odomenters and other parts and work fine.
    thnks
    pepi's Avatar
    If you have high level tools like Autohex or AVDI there is no problem for adaption EGS .
