Hello everyone,
I have a Audi Q7 3.0 TDI 2009. Somebody have done before me DPF off and the car has work for some month. Now i have a error code :
P0607-Control Unit Performance
Car crank but not start. If I clear the error car start and everything is OK, but when I turn off again the car it will not start again. So if i clear again this error car start again but not start if i turn off. So any help for this problem please.
I think the problem is in software, so any help please. The ECU is :
Bosch EDC17CP04
4L1 910 401 N
SW: 1037518084
evisdaci (24th June, 2020)
Doesn't work mate. Now no error code but car not starting. Engine crank but no start. No error code. Any other solution please.
Any help please
Write this
if still doesn't work then your ecu hardware is damaged
Best Regards
2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
Official Magicmotorsport DistributorCode:FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
Official Autotuner Distributor
Official Alientech Distributor
Tomorow I will try and let me know. But today I have done some testing with some diferent dump file, and finally I think the problem is in eeprom dump. I have download another BDM dump file from another guy and write in my ECU only eeprom and no more P0607 and car start and turned off again because "incorrect key", because is immobiliser active and car cant start normally. So car start every trying and turned off again (turned off from IMMO), so I think the problem is in eeprom dump.
