Results 1 to 4 of 4
    Default DM800 tuner output
    Hi guys,
    Trying to figure out if the tuner output on the dm800s is of any use.
    Basically i have a cable ran from the tuner output on my dm800 to a tv in another room. All i'm trying to do is use it the same as the RF2 output on a sky box but i can't seem to get the tv to tune to it.
    Is there a setting i need to enable in my dm800 (i can't seem to find anything thats obvious in thesetup menu!)
    Cheers
    North Wales
    Usually, your DM will need to be on standbye for this to work, otherwise the DM takes over and uses the signal itself, when its on standbye your RF2 going to your sky box should work okay..
    Quote Originally Posted by Superman View Post
    If the box is in standby how can i view anything onth eother tv?
    Or is it just supposed to work as loop through for anouther reciever, eg. freeview?
    Cheers
    North Wales
    Its a loop through function, so you feed the cable from the output to the back of your other box i.e sky box.
    Hope this helps.
