Results 1 to 7 of 7
    Aug 2015
    Default a3 2010 white cluster
    hi
    i want make a new key to a3 2010 with white cluster and with Simos engine ecu.
    i tried avdi and smok but both coulnd not do over OBD
    can this cluster just be done over xprog ? no obd solution ?
    thx
    pepi's Avatar
    Jan 2010
    Are there all keys lost ? I have read many times this cluster with AVDI without problems.
    Sent from my SM-G925F using Tapatalk
    Aug 2015
    No i have a working key avdi reads just 00 if i read eeprom 2kb
    Dec 2017
    for the all key lost solution the eprom must be changed did you do that the org eprom save and use as s key .... I have the same problem but search with 2 audi micronas tachos a3 and tt with smok and avdi no read and write possible .... touran viston tacho goes without problems with both tools
    and look up to what address he reads the eprom with 00 that is about 50% exactly the error I have synonymous
  5. The Following User Says Thank You to A3fDevil666 For This Useful Post:
    offsystem (20th January, 2019)
  6. #5
    Aug 2015
    Quote Originally Posted by A3fDevil666 View Post
    Yes correct it reads just 50% of ee.
    How to use original eeprom as skey?
  7. #6
    Jan 2016
    Maybe someone played with it ??
    No foults stored ??
    Try as AKL situation. Should work.
    When it doesnt I always read eep+flash and make TP by dumps.
    Rgs.
  8. #7
    Aug 2015
    Just for info vvdi did it at 1st attempt
    Avdi support told me cluster is not supported. Lol
