Results 1 to 14 of 14
    Jan 2019
    SCOTLAND
    Default just bought a tuning file from tuner ......... no power increase
    hi, i sent my ecu file to a tuner and 1 hour later i was sent file back "tuned" i then wrote the file to ecu and all was fine, took car for a run and no difference, could it be that ive just had same file sent back and changed for it? anyone be able to look at files and see if there is any change?
    where are the file?
    Jun 2013
    EU
    No one will if you not upload them
    DK Veteran daniel guerra's Avatar
    And more details on the car, sometimes the car has 2 databanks, and tuning is only in one databank.
    MagnetoCar's Avatar
    Jan 2019
    without a file it will be hard to help
    Jan 2019
    SCOTLAND
    sorry, new to this forum, its from a 2010 Renault Kangoo 1.5dci 68hp, i used a kess v2 selecting delphi 1.2 ecu, i have id then read then after tuner modified file i wrote to ecu, if you need any more info please ask HW 8201112311 SW8201145249
    Jan 2019
    SCOTLAND
    this is original file from car
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by brechin47 View Post
    did you id the ecu?
    what tool you using?
    Jan 2019
    SCOTLAND
    im using kess 2.47 and yeah i did id then read then write once i had new file, seems like its not actually writing or im getting the same file back
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    post id .
    Jan 2019
    SCOTLAND
    HW 8201112311 SW 8201145249 ?
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    There are changes in your mod file.
    If you not satisfied with the result... contact with your seller and solve the problem.
  13. #13
    Jan 2019
    SCOTLAND
    I asked for a stage 1 tune, ive been assured the map is 15% increase but it’s not noticeable at all, I’ve now read ecu again after *tune sand going to have it read to see if ecu is taking the file
  14. #14
    Jun 2022
    Need help with egr off Renault kengoo 2.
