Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 54
  1. #31
    Jun 2013
    EU
    Quote Originally Posted by pocinas View Post
    it is Ok if i share you just 13 Lines Readed Throught WinHEx from New Card after FILLIN Zeros and used in KESS/ktag. I got some instr. but i am stuck.
    Attached file is from KTAG 7.020 with new sc card Filled 00, and generated via ktag/ksuite
    I would say your key file is bad.
  2. The Following User Says Thank You to morgano For This Useful Post:
    pocinas (2nd April, 2019)
  3. #32
    Apr 2019
    Quote Originally Posted by morgano View Post
    And you can use the standard image for red kess as your sd cid is the common one (based on the image you uploaded).
    https://yadi.sk/d/GCe8tbJu9OH36Q
    Do we just copy and paste the file under windows?
    從我的iPhone使用Tapatalk 發送
  4. #33
    Oct 2011
    Germany
    I say if your key file is from a new SD card, then nobody can say itīs bad or good.
  5. The Following User Says Thank You to bergbahn For This Useful Post:
  6. #34
    Jun 2013
    EU
    Quote Originally Posted by bergbahn View Post
    You are 100% wrong! I can say it.
    That key file is not valid to make a working sd card.
  7. #35
    Feb 2013
    UK Bristol
    Thanks a lots gentelmens for Offer build me IMAGE. I found solution so i do it Self.
    My post helps you? Please Hit Buttons
  8. #36
    Jun 2013
    EU
    And the key file you uploaded here is not the valid one for your card, right?
  9. The Following User Says Thank You to morgano For This Useful Post:
    brouk5 (9th January, 2020)
  10. #37
    Feb 2013
    UK Bristol
    Don' t sure now but i can check again this 13 lines for you just to knows who have right..
    I using little diffrent technics without CID with sd psychics which i wrote yesterday here
    Post 111
    https://www.digital-kaos.co.uk/forum....php?p=3542456
  11. The Following User Says Thank You to pocinas For This Useful Post:
    gas43 (6th July, 2019)
  12. #38
    Jun 2013
    EU
    Check please if your actual working sd key matches the one you uploaded here.
  13. #39
    Feb 2013
    UK Bristol
    MORGANO you have RIGHT, key from my NEW SD Card which i posted in post #30 is wrong. To test i generated image with this key and KSUITE doesnt work.
    Correct key is like in photo bellow
    and 2nd photo which i share in post 30 with wrong Offset
    The Diffrence is i share KEY with starting OFFSET 00005010 but i should start 7 lines later from 00005070
  14. The Following User Says Thank You to pocinas For This Useful Post:
    morgano (3rd April, 2019)
  15. #40
    Jun 2013
    EU
    Thanks for clarifying, was obvious to me the key was wrong
  16. #41
    Jan 2019
    Best Country of the world, GR
    Quote Originally Posted by Digital Under View Post
    No need read CID, no need use linux, no need use any program
    -Erase new microSD
    -Put microSD into Kess or Ktag, connect to computer and start Ksuite
    -Create image in hex-editor and post here
    Ι did a mistake and i erase the sd card of my kess... is there a solution?
    can I put again the erase microsd into kess, create image and post here?
    Thanks!
  17. #42
    Jun 2013
    EU
    Yes you can.
  18. #43
    Feb 2013
    UK Bristol
    Is not correct..
    Card before put to kess should before filled 00 via hex editor
  19. The Following User Says Thank You to pocinas For This Useful Post:
    gas43 (5th July, 2019)
  20. #44
    Jan 2019
    Here my image of erased sdcard (format was fat, not fat32), after connect into kess v2 5.017 red pcb and start-open ksuite http://www.filedropper.com/sdcard
  21. #45
    Jan 2019
    I would like to thank publicly the member "pocinas" who create a new sd card and saved my kess!!!!
    It is very important that we have such excellent members in our forum!
    The unbranded sd cards, make big problems, guys...
    Thank you again!
