    Dec 2010
    Default Peugeot IAW4MP2.01 Virgin
    Hello!
    Could you please help me with virginising this dump? 29F200 included - solution form IUD not work...
    thanks! Peugeot 307, RFN 2.0 16V 2001.
    Le-Mans's Avatar
    Jun 2017
    try this solution pass via pm
  3. The Following User Says Thank You to Le-Mans For This Useful Post:
    xdamdamx (21st January, 2019)
    Jan 2019
    Usa
    Default virgin
    here is you virgin
    if i help you don't forget thanks and reputation
  5. The Following User Says Thank You to ayoubovitch For This Useful Post:
  6. #4
    Dec 2010
    LeMansSeries - your file is the as IUD3 , it doesn't work.
  7. The Following User Says Thank You to xdamdamx For This Useful Post:
    Le-Mans (21st January, 2019)
  8. #5
    Dec 2010
    Still looking for a working file
  9. #6
    Dec 2010
    Sorted it a little backwards - I used a dump with known PIN, virginized BSI and programmed this known PIN, and programmed a new PCF7936 transponder. car started.
    None of above virgin files worked.
  10. The Following User Says Thank You to xdamdamx For This Useful Post:
    Le-Mans (22nd January, 2019)
