Results 1 to 3 of 3
    Jul 2012
    Default Passat 3c b6 ppd1.2 2007 additional key
    hi,
    i would like to have a 2nd key for my car.
    is there a way to adapt a used key?
    maybe with new transponder?
    Oct 2014
    Netherlands
    Take a new unused ID 48 transponder.
    With proper tools write CS data to transponder.
    With proper tools convert transponder to TP23.
    Lock the transponder
    Now using a tool like VCDS you can easily learn this transponder to CCM module using Adaptation channels (you need PIN code).
    It is easiest to read eeprom from CCM module first to obtain CS and PIN (using proper tools or by forum help)
    Used keys are locked if you don't know the password/pincode you cannot unlock them, so you cannot reuse them.
  3. The Following User Says Thank You to H2Deetoo For This Useful Post:
    aef (22nd January, 2019)
    Jul 2012
    Thanks!
    I will try to open CCM and read 95320 at first.
    regards
