Results 1 to 2 of 2
    Jan 2019
    turkey
    Default suzuki swift key code..
    i need help to find last three digit of hu87r key cutting code.. bittings: 3,2,4,2,1,3,4,?,?,? condor is not giving, can anyone help.. there is no key code on door lock and bittings are missing in door lock. i need last three (8,9,10) bittings.
    Dec 2010
    Nottingham
    where did you get the bittings you have from ? door lock ?
    if the door lock and if the 10 cut lock then the door would normally house positions 2 to 8 and not 1 to 7 ? also in the 10 cut lock position 10 is almost always a 1 or a 3 cut . so if a model after 2004 and you actually have the correct bitting from 2 to 8 there is only 1 possible key on instacode using that bitting in 2 to 8 of 1324213421 you could try this
    what year is this car ?
