Theres no immo data in eeprom. All in mcu.
hi
we try to make key on this car but after programing fem car can't start with old and new key
remote on old key work and car crank but can't start
error in fem is ISN wrong or damaged
can anyone help me and check dump from this bmw f030?
FEM/BDC security key: 560194A68D5A4298CAB5C8191FF1BCE5
DME/CAS security key: 65133D08F411E40580F16906BC942404
Key/CAS security key: ED56CAF37495DC490000000000000000
ECU ISN: 8845F7FB8084384C6DA7A3F5C801F84D
davorOS (21st January, 2019)
Did you write back car config?
And did you read isn from ECU by obd?
The key you have programmed is incorrect part number.
I have been through this many times.
Delete the key you programmed and program a correct key into the same slot, car will start.
davorOS (23rd January, 2019), doctore (23rd January, 2019), HeXeN (24th January, 2019), milehighlockdoc (23rd January, 2019)
hi
we have change eeprom with new one 95128 write back old dump and car start with old key,
for now only keyless not work but that should be programmed with esys
today I will try to make new key and see results
Youre busted now. You will not restore keylesd function or remote. This is already tested. You can do what you want,flash etc. Iny solution is new fem and adaptation
What fault codes does the FEM have?
all working with new key
remote and keyless starting
something get wrong with original key in process
but car is finish when I made new key
Just renew and reprogram old key,will work...
Had a similar case on CAS4 F01.
I just renewed and reprogrammed old and new key.
Both worked after.
Cas4 totaly diferemt
So what?!
I told what the member should try,instead of trolling around like you.
You send a member to buy a brand new part,while the old one works.
Shit happens to everyone,it is easiest to send someone to buy new parts,because money doesn't come from your pocket.
Look at your posts,they are full of the same content.You did something where everyone else failed.
Like the Nissan Rogue thread.
Everyone else has had problems with that car,while you did it flawlessly.
Even Nissan dealers have to change BCM when coding keys.
Troling? Pfff im talk from experience. You talked from old grannys fairytales.
About how to restor bricked fem ask rola. He will tell you how long and how effort took. Bring back car to life.
Rogue i did turn on tool took more time than add key
Prove https://m.facebook.com/story.php?sto...49436631839932
eliaselias (23rd January, 2019)
