Results 1 to 12 of 12
    Integy's Avatar
    Sep 2015
    Default POLARIS ATV 1000CCM3 ME17.9.74 SPEED LIMITER OFF, AND STAGE1
    Hello, like in title, I need to make stage1/unlock, to speed minimum 140km/h. After classic Speed Limiter off speed is only 120km/h.
    Orginal File:
    Attachment 589250
    Best regards Piter
    EDIT: Now right file.
    May 2015
    hello not able to open file with speed limiter off. Password protected?
    In EEP
    this is ktag backup post file separaty
    Best regards
    Integy's Avatar
    Sep 2015
    Right file added. Sorry
    Sweden
    Did you get limiter off on this?
    I need to get this polaris speedlimiter off, pm if you can help
    Integy's Avatar
    Sep 2015
    If someone have problem , I can help with SL Off, Start from gear, Vmax up. Best regards
  7. The Following User Says Thank You to Integy For This Useful Post:
    boxsport (8th August, 2020)
    Jan 2019
    Somewhere between Continents
    Quote Originally Posted by Integy View Post
    Hello Mate.
    What tool do you use to read this ECU?
    Can Ktag clone do it?
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
    Oct 2020
    Quote Originally Posted by boxsport View Post
    Hello Mate.
    For Bosch Tricore I use 2 different softwares... Chiploader and BitBox. Have you tried any of these?
  10. The Following User Says Thank You to edgararroyo For This Useful Post:
    boxsport (21st October, 2020)
  11. #9
    Jan 2019
    Quote Originally Posted by edgararroyo View Post
    No, I don't have those softwares / hardware... I need to see if in the following months I'm able to invest a bit more in equipment and i already had thought on bitbox or PCMFlash
  12. #10
    Mar 2013
    if not solved with atv. contact in pm.
  13. #11
    Integy's Avatar
    Sep 2015
    Ktag clone read good this ecu.
  14. #12
    Mar 2013
    why open ecu ? tool original work on this ecu with bench mode...
