Results 1 to 4 of 4
    Mar 2015
    Default Hot start problem ? MJD8F3.F6 51918357
    Ive got problem with a car (Fiat Fiorino 2012 1.3)
    The car is start but after few seconds is stop
    We bought brand new injectors still the same , we change everythng from fuel filter to injectors . We got all parts from the running car but our stop after few seconds
    Now we got another ecu same numbers ect... We make a clon eeprom and flash but still the same
    Any one can have look at the my files please mayby is a fault in flash dont know and i hope somone help me
    Thank you
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    When starting the car you still have pressure in common rail? And how much?
    have a table of errors? have you check the high pressure pump?
    Jun 2015
    if you have passed the dignostic then post us the fault codes.
    Jun 2015
    I did not understand your problem.
    the engine stops when it is hot??
    the engine does not stop cold??
