Results 1 to 3 of 3
    Jan 2014
    South Africa
    Default MINI R56 NEED HELP
    Hi everyone,i got a mini ecu which is damaged and would like to change with another used one,cant get the exact one,can one help and tell me which other ecu numbers will be compatible
    Attached is the picture
    Thank you
    Jan 2019
    France
    these esu should compatible ( bosch database) MEVD17.2.2
    0261S05720, 0261S05895
    0261S06022, 0261S06167, 0261S06199, 0261S06200, ...340, ....382, ....383,...658,...659,...660,...661
    02161S08046, 0261S08047
  3. The Following User Says Thank You to red69 For This Useful Post:
    shinehead (13th June, 2019)
    Jan 2014
    South Africa
    hi, sorry never said thank you that time as im still learning to use the dk site, but getting better , can u help with a compatible dme numbers for this ecu ,0261206902
