Results 1 to 12 of 12
    Jun 2008
    Default Nabilosat Server down?
    Just installed latest nabilosat v12 blackhole to my dm800hd but unable to access nabilo server (for several days now - cant get on their site online either). need to manually install latest cccam emu from ihad but manual install doesn't permit this as not a nab file. have ftp'd emu from alternative site to tmp folder using dcc but got no further. can anyone advise how to manually install files with this image as unable to clear anything until this sorted? have managed to ftp satan keys over but no use unless emu installed.also any news on why their server etc unavailable?
    Feb 2009
    nabilo is available on my dm500. so it should be available to you on your 800hd as well.
    V.I.P. Member westkill's Avatar
    May 2008
    heres 2.12 cccam full
    this will over write your cccam.cfg so take a backup if needed
    to manual install
    dm800-s=1.1 m triax motorised dish=titanium twin lnb
    DIGITAL KAOS BEST SITE ON THE NET
    please use the thanks button if someone has helped
    North Wales
    The server seem'd okay here this morning, check your internet connect, then maybe try a hard shutdown, uplug then re-plug.
    Thank
    Jun 2008
    Thanks to all who have replied - will have a go later with suggestions made and advise of progress accordingly
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    Enigma1 use a different server to Enigma2. I have just had a friend confirm Nabilo E1 server is working.
    Read the Rules here; they apply to Everyone.
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 Motor
    Jun 2008
    all working ok now - enigma2 server was down causing the problem but back online now. thanks to all who responded
    North Wales
    Glad your all sorted matey, here to help
    Super
    hello there ,
    what is latest nabilo image for DM0500 ?
    North Wales
    Use Niablosat v 0.8 MaxVar.
    Super
    Thanks for the ccam files
    Mar 2008
    Coatbridge
    I eventually ditched Nabilosat purely because their Server was not reliable.
    I've switched to PLi Jade 3, the PLi server is perfect, I've never had an issue.
