Results 1 to 8 of 8
    Oct 2018
    Default Trafic Injector Codes OBD-BDM
    Renault Trafic II
    2008 Diesel
    2.0 Dci 115ps
    EDC16.....
    I read a lot that injector codes can get be lost after flashing modified file and that the car won't start.
    If Ksuite gives me the option to read the injector codes before reading the Ecu and let's sy that the car won't start...
    Can I then learn the codes back by Ksuite by uploading the saved inj. file or do I need to do it with a diag tool?
    Have also Ktag but guy don't want his ecu opened
    Jan 2013
    Inside ECU
    Use galletto to write injectors on traffic or vivaro. Injectors code can be lost on flash but you can write back
  3. The Following User Says Thank You to leotdx For This Useful Post:
    TilQ34 (25th January, 2019)
    Oct 2018
    Can I flash it back by Ksuite self Tool=>Injector codes codify(after flashed modded)?
    Or just another tool like Delphi...
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by TilQ34 View Post
    Yes you can also some scan tool can read them
  6. The Following User Says Thank You to teerak2uk For This Useful Post:
    Oct 2018
    Thanks for reply's...
    Now it's more clear for me..
    But I convinced him to do it by the ECU, BDM
    Didn't do it before, first time that Im gonna use my Ktag, but don't found any issues on the net by full BDM read
  8. #6
    Oct 2017
    Earth
    KESS Clone and galleto do these over OBD no problem, just read injector codes before writing and after writing flash write back injector codes, thats all
  9. #7
    Oct 2018
    So recoding the injector codes after flashed mod file... But not via Kess=>Tool>learn/codify inj codes..
    Only by using diag tool..?
  10. #8
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Yes you can do it with kess
  11. The Following User Says Thank You to teerak2uk For This Useful Post:
    TilQ34 (26th January, 2019)
